Re: trouble shooting frustration [Re: RustyM] #2956558
08/23/21 12:47 PM
08/23/21 12:47 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Thanks for the update,, keep us posted
Re: trouble shooting frustration [Re: CSK] #2956723
08/23/21 07:38 PM
08/23/21 07:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What were the bolts, what was the torque, and what lube was used to install the heads?
Re: trouble shooting frustration [Re: CSK] #2957661
08/26/21 03:37 PM
08/26/21 03:37 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Machine shop said 3 thou cleaned up the heads and that it doesn't take much at all to let these mls gaskets between layers.
Valves/seats/seals all good.
We will check bolts.
Re: trouble shooting frustration [Re: fast68plymouth] #2957665
08/26/21 03:42 PM
08/26/21 03:42 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Bolts are ARP, used Arp thread lubricant. Don't have tq specs here with me .
Gary is wondering is he left a little water or fluid in the bolt holes that compressed and we didn't get actual tq values.
Im not sure, wasn't there when they were torqued. Will be this time with my torque wrenches etc.
Just has to be right for three more dates, which is actually 4 races.
Then end of the season dyno pulls, after that we pull it down, box up the parts that are coming to you.
Cylinder walls all look good but, time for a rebuild even if we weren't going to the new block.
We looked really good to see if anything "kissed" since pistons are out of the hole so far.
Re: trouble shooting frustration [Re: RustyM] #2957860
08/27/21 03:03 AM
08/27/21 03:03 AM
Hopefully you are going to retest the leak down on it after reassembly and maybe running it long enough to get some heat in it, aren't you work scope twocents
Re: trouble shooting frustration [Re: Cab_Burge] #2957900
08/27/21 09:14 AM
08/27/21 09:14 AM
N
NITROUSN Offline
NITROUSN  Offline
N
My bets are that there will still be air in the crankcase on a leak down.
Re: trouble shooting frustration [Re: Cab_Burge] #2962339
09/08/21 10:02 PM
09/08/21 10:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
iagree drinking
