Re: Was the Hemicuda convertible SS/E class?
[Re: ragtop]
#2956637
08/23/21 03:59 PM
08/23/21 03:59 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
I'm thinking that car was ran in SS/EA at the Winternationals, it was rumored among us racers at that race that it was a later body converted to a 1971 I was under the impression that Mopar, Dodge and Plymouth didn't make any 1971 Hemi E body convertibles in 1971
[Re: A/MP]
#2956659
08/23/21 04:38 PM
08/23/21 04:38 PM
Posts: 2,670 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Since the hardtop was D I assume the convertible was E. And yes Plymouth made 1971 Hemicuda convertibles.
2011 Drag Pak Challenger
[Re: topside]
#2956732
08/23/21 08:01 PM
08/23/21 08:01 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
There used to be one at Havana a lot. It was /EA.
[Re: slantzilla]
#2956735
08/23/21 08:19 PM
08/23/21 08:19 PM
Posts: 11,639 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If I read it correctly, looks like a natural E car.
[Re: CMcAllister]
#2956758
08/23/21 09:31 PM
08/23/21 09:31 PM
Posts: 1,620 MA
ragtop
MA
If I read it correctly, looks like a natural E car. Where could I find this list that you refer to? Thanks.
[Re: A/MP]
#2956768
08/23/21 09:48 PM
08/23/21 09:48 PM
Cab_Burge
You would need the find and dated HP/WT/CLASS spreadsheet from NHRA to get the correct answer. You can always move up or down 1 class by playing with weight. Too may /EA class car at an event, you would just +/- weight. Too many of the same class cars would give you a greater chance to run same class cars which means "all out, whoever gets to the finish line first wins". I don't think NHRA allowed adding or subtracting weight to change classes in Stock or Super Stock until much later, maybe 1976 or later. I remember NHRA used the "factory provided shipping weight" as the minimum weight for each car until they started adding the 170 Lbs. for the drivers weight to the shipping weight, shortly after that they added the ability to add or subtract weight to the cars to change classes
[Re: Cab_Burge]
#2956835
08/24/21 08:26 AM
08/24/21 08:26 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
My 1971 Hemi Four Speed Challenger ran in SS/D in 1971 and 1972, then in MP in 1973 and Don Cloake had built a 1970 440-6 Cuda Convertible into a 1971 Hemi Cuda Convertible and it ran in SS/E in 1971 / 72 at the same time. Both the Challenger and the Cuda ran in NHRA. My Challenger is much lighter than the Cuda Convertible. i
1971 HEMI E BODY REGISTRY
[Re: ragtop]
#2956889
08/24/21 11:11 AM
08/24/21 11:11 AM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
C or D class is what my memory says....But here's a picture of one at our track.
[Re: ragtop]
#2956898
08/24/21 11:39 AM
08/24/21 11:39 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If I read it correctly, looks like a natural E car. Where could I find this list that you refer to? Thanks. NHRA classification guide. You have to look up the car (weight), rated HP over the engine and do the arithmetic - weight/HP = factor = class All I have is current info,
[Re: JackZ]
#2956933
08/24/21 01:09 PM
08/24/21 01:09 PM
hemicar1971
Chicago Blackhawks
Back in the day I never saw a SS/D or SS/DA Convertible E Body. All the ones I ran against were SS/E or SS/EA. My Challenger that is basically an ordered drag car is lighter than most 1970 and 1971 Challengers. It still has the modifications from 1972 in the car and it weights in at near 3400 lbs. The Body has no undercoating, sound deading all the extra stuff the factory puts on never got put on. I took the louvers and wing off for this weight but left the shaker and that is without the Jack and Spare Tire. I have a TA hood for the car that would lighten it up even more. I also have an aluminum case Hemi Four Speed that gets used now and then. I would think a convertible must weight around 200 or more lbs more that the advertised weight of an E Body Hardtop. There were quite a few Hemi E Body Convertibles that were raced. Can not remember what other cars were in that class.
[Re: Dragula]
#2956939
08/24/21 01:24 PM
08/24/21 01:24 PM
Posts: 3,089 Michigan
A727Tflite
C or D class is what my memory says....But here's a picture of one at our track. The subject is Super Stock. Correct me if I am wrong - this car is a stocker.
