72 Cuda Knob under steering wheel/dash? #2956808
08/24/21 12:40 AM
08/24/21 12:40 AM
PA
JKCuda Offline OP
JKCuda  Offline OP
PA
Hey everyone. After a few long years of being in storage I've finally started working on our 72 Barracuda. Mainly mechanical stuff, but I'm trying to clean up some messy wiring, etc, from the previous owner. When working under the dash I noticed there appears to be a cable/knob that is missing from right under the dash to the left of the steering wheel that looks similar to the knobs used for opening the air vents. Any idea what this is, I have it circled in red? The knob is missing, it looks like someone yanked on it and broke the end off. Just trying to figure out what I'm missing so it can be replaced.
Re: 72 Cuda Knob under steering wheel/dash? [Re: JKCuda] #2956812
08/24/21 01:31 AM
08/24/21 01:31 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
If it goes out to engine bay, could have been a choke cable. Not unusual for back in the day
Re: 72 Cuda Knob under steering wheel/dash? [Re: PhillyRag] #2956813
08/24/21 01:48 AM
08/24/21 01:48 AM
PA
JKCuda Offline OP
JKCuda  Offline OP
PA
That's kind of what I was wondering but most of what I saw said these didn't have manual chokes. I guess someone could've added it. I'll have to trace the line into the engine bay and see where it runs I guess. I'm converting it to EFI anyway so if that's what it is, it can go!
Re: 72 Cuda Knob under steering wheel/dash? [Re: PhillyRag] #2956837
08/24/21 08:28 AM
08/24/21 08:28 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Yup, back in the day I put a choke cable on my 318 when it was converted to a 4 barrel carb.
Re: 72 Cuda Knob under steering wheel/dash? [Re: EW1BH27] #2956882
08/24/21 10:50 AM
08/24/21 10:50 AM
PA
JKCuda Offline OP
JKCuda  Offline OP
PA
Good to know, I'm assuming that's what it is then because it doesn't look factory. Thanks fellas! Wish this heat would break here in PA so I could get out there. Too damn hot in the garage right now!
Re: 72 Cuda Knob under steering wheel/dash? [Re: JKCuda] #2956912
08/24/21 12:05 PM
08/24/21 12:05 PM
moparx Offline
moparx  Offline
choke cable from the parts store for sure. into the junk pile it goes.
it looks like the heat will be here for the next week or so. i leak like a sieve in any temperature over 35* ! biggrin
where in pa are you ? i'm in brookville. [exit 78 I-80]
beer
Re: 72 Cuda Knob under steering wheel/dash? [Re: JKCuda] #2956970
08/24/21 02:54 PM
08/24/21 02:54 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
Could also be from one of those aftermarket hood releases.
Re: 72 Cuda Knob under steering wheel/dash? [Re: 57Fury440] #2957027
08/24/21 06:35 PM
08/24/21 06:35 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
probably a manual choke cable.
another possibility to think about.
back in the days, in COLD weather climates, a aftermarket fast idle cable was pretty common also. you could start the car. boost the idle with the cable, walk away and you didn't have to hang around until the car warms up to drive it. this way you didn't have to worry about the car stalling after the auto choke opened and the carb released the fast idle. a cable was much cheaper and easier than paying $$$ for a good tune up and repairing the carb on a car that didn't like to idle when cold. after it warmed up it ran just fine.
perception is 90% of reality
Re: 72 Cuda Knob under steering wheel/dash? [Re: moparx] #2957098
08/24/21 10:11 PM
08/24/21 10:11 PM
PA
JKCuda Offline OP
JKCuda  Offline OP
PA
beer
Haha same here. I can't stand this humidity. I'm in Mechanicsburg, about 5-10 mins West of Harrisburg. I need to get a mini split setup for my garage. Cool for the summer and not freezing for the winter
