Re: isoclamp removal #295656
04/22/09 01:05 PM
04/22/09 01:05 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
I know this may sound half a$$ is the hole in the spring perch 1 5/8 if so this is what I did on a 73 New Yorker with iso clamp set up. I took a 1 1/4 craftsman shallow socket 1/2 inch drive and shortened it down so it would fit flush with the spring perches. The 1/2 inch drive in the socket fits the 1/2 spring bolt head perfect and the outside diameter of the socket is 1 5/8 and fits the hole in the perch perfectly. Just trim the socket enough to butt against the axle tube to hold it in place.
Re: isoclamp removal [Re: patrick] #295657
04/22/09 02:37 PM
04/22/09 02:37 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
eliminating the iso-clamp setup and retaining the stock 7 1/4" axle is a waste of time. if you want to eliminate it, get an 8 3/4 or 8 1/4 out of a '68-70 B body, spring centering bolt and U bolts for the same, and the associated shock plates. it'll pretty much bolt right up.
valid up 72s
Re: isoclamp removal #295658
04/22/09 03:19 PM
04/22/09 03:19 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
i planned on doing away with it anyways. for adding the leafs do you guys use one of the stock ones or do you buy an aftermarket kit?
Adding a leaf to the existing spring pack will not raise the rear ride height any, as the rearend sits on top of the leaves. Plus, the lower IC bracket would be too short once you add another leaf.
I see in your other post you've added longer shackles. I hate to say this, but I'm going to-- buy some air shocks and be done with it. They'll give you a bit more clearance, are relatively cheap, and are a bolt-in deal.
Re: isoclamp removal [Re: In_The_Pink] #295659
04/22/09 03:39 PM
04/22/09 03:39 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
or spend the $250 instead of half-a$$ing it and buy new 5 leaf springs from ESPO, or spend $100 getting yours rearched.
2017 Grand Cherokee Overland
Re: isoclamp removal [Re: NachoRT74] #295660
04/22/09 03:41 PM
04/22/09 03:41 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
valid up 72s
No, '71 up rears are 3" wider (64" vs 61") and perches are 3" (47" vs 44") further apart. '68-70 rears are within 1/2" for both measurements as an F/M/J rear (~61" wide, 44.46" perch width).
Re: isoclamp removal [Re: patrick] #295661
04/22/09 03:54 PM
04/22/09 03:54 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That's NOT true. The springs will arch more with an extra leaf in it. That will still raise the rear. I had an extra leaf put in the springs on dad's Challenger because the stockers were sagging badly. That did the trick.
Now that the car is being restored however...I will be buying NEW springs. The add-a-leaf trick is just a bandade.
Re: isoclamp removal [Re: patrick] #295662
04/22/09 07:36 PM
04/22/09 07:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
valid up 72s
I mean talking about kind of perches without isolation on B bodies. They began on 73
Re: isoclamp removal [Re: NachoRT74] #295663
04/23/09 08:59 AM
04/23/09 08:59 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
ok, true, I'll give you that, isoclamps didn't start until 73, but a 71-72 rear won't work without using high offset wheels (say, late model mustang), and rewelding the perches.
Re: isoclamp removal #295664
04/23/09 09:00 AM
04/23/09 09:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
all the b bodies around here have been crushed for scrap or are in peoples garages.
watch craigslist in your area. I'm sure you could find one.
Re: isoclamp removal [Re: patrick] #295665
04/23/09 09:12 AM
04/23/09 09:12 AM
Anonymous OP
Anonymous OP
yeah the whole car but we dont have a place to keep most of a car. i took a set of shock plates off of a nissan. they fit perfectly on a lebaron at the jy. then ill just make a plate for the bottom.
Re: isoclamp removal #295666
04/23/09 10:49 AM
04/23/09 10:49 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I meant you could probably find a B body rear axle on craigslist...
Re: isoclamp removal [Re: patrick] #295667
04/23/09 11:12 AM
04/23/09 11:12 AM
Anonymous OP
Anonymous OP
ive been looking for over a month now in ny, ma, and pen. still nothing any good.
