Re: isoclamp removal
#295658
04/22/09 03:19 PM
04/22/09 03:19 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
i planned on doing away with it anyways. for adding the leafs do you guys use one of the stock ones or do you buy an aftermarket kit?
Adding a leaf to the existing spring pack will not raise the rear ride height any, as the rearend sits on top of the leaves. Plus, the lower IC bracket would be too short once you add another leaf.
I see in your other post you've added longer shackles. I hate to say this, but I'm going to-- buy some air shocks and be done with it. They'll give you a bit more clearance, are relatively cheap, and are a bolt-in deal.
[Re: In_The_Pink]
#295659
04/22/09 03:39 PM
04/22/09 03:39 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
or spend the $250 instead of half-a$$ing it and buy new 5 leaf springs from ESPO, or spend $100 getting yours rearched.
[Re: NachoRT74]
#295660
04/22/09 03:41 PM
04/22/09 03:41 PM
patrick
Grand Haven, MI
eliminating the iso-clamp setup and retaining the stock 7 1/4" axle is a waste of time. if you want to eliminate it, get an 8 3/4 or 8 1/4 out of a '68-70 B body, spring centering bolt and U bolts for the same, and the associated shock plates. it'll pretty much bolt right up.
valid up 72s
No, '71 up rears are 3" wider (64" vs 61") and perches are 3" (47" vs 44") further apart. '68-70 rears are within 1/2" for both measurements as an F/M/J rear (~61" wide, 44.46" perch width).
[Re: patrick]
#295661
04/22/09 03:54 PM
04/22/09 03:54 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
That's NOT true. The springs will arch more with an extra leaf in it. That will still raise the rear. I had an extra leaf put in the springs on dad's Challenger because the stockers were sagging badly. That did the trick.
Now that the car is being restored however...I will be buying NEW springs. The add-a-leaf trick is just a bandade.
[Re: patrick]
#295662
04/22/09 07:36 PM
04/22/09 07:36 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
valid up 72s
I mean talking about kind of perches without isolation on B bodies. They began on 73
[Re: NachoRT74]
#295663
04/23/09 08:59 AM
04/23/09 08:59 AM
patrick
Grand Haven, MI
ok, true, I'll give you that, isoclamps didn't start until 73, but a 71-72 rear won't work without using high offset wheels (say, late model mustang), and rewelding the perches.
[Re: patrick]
#295665
04/23/09 09:12 AM
04/23/09 09:12 AM
yeah the whole car but we dont have a place to keep most of a car. i took a set of shock plates off of a nissan. they fit perfectly on a lebaron at the jy. then ill just make a plate for the bottom.
#295666
04/23/09 10:49 AM
04/23/09 10:49 AM
patrick
Grand Haven, MI
I meant you could probably find a B body rear axle on craigslist...
[Re: patrick]
#295667
04/23/09 11:12 AM
04/23/09 11:12 AM
ive been looking for over a month now in ny, ma, and pen. still nothing any good.
