Re: 70 t a hood striker
[Re: Alaskan_TA]
#2955751
08/20/21 04:54 PM
08/20/21 04:54 PM
Posts: 21,449 It's a dry heat
gtx6970
It's a dry heat
Thanks Barry, when I posted it, I was trying to remember when I did some work on a AAR a few years back and thought it had the pop up spring. But I wouldn't bet my life on it either
[Re: gtx6970]
#2955889
08/21/21 05:52 AM
08/21/21 05:52 AM
Posts: 10,142 A Red State
SNK-EYZ
A Red State
Thanks Barry, when I posted it, I was trying to remember when I did some work on a AAR a few years back and thought it had the pop up spring. But I wouldn't bet my life on it either I'm pretty sure that an AAR has a pop-up spring. A T/A will not. The T/A hood goes all the way to the front whereas an AAR's hood has a header panel in front of it. Without the spring lifting the AAR hood would be tough.
[Re: SNK-EYZ]
#2955896
08/21/21 08:08 AM
08/21/21 08:08 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
No spring on AARs either. The proper way to open an AAR hood is to insert your hand palm down into the scoop, curl your fingers to grasp the support structure underneath to open. (opening with the top of the scoop cracks the sides)
[Re: fastmark]
#2956006
08/21/21 02:32 PM
08/21/21 02:32 PM
SNK-EYZ
A Red State
No pop up spring on an AAR. I’ve got two now and had several over the years. You reach up and grab the opening in the scoop to open it. Glad you was not betting your life. Lol. I wouldn't have bet anything on it at all. I've never owned a T/A or AAR myself, I've never been into the small block powered cars only big blocks and Hemi's. I'm pretty sure that I remember someone that had an AAR back in the 80's that had the pop up spring on it. Was it factory? I have no idea, maybe they were tired of fighting to get the hood open and added the spring to it.
