Guys,
I need to replace the wire, or just the connector on my trucks wiring harness that goes down to the starter solenoid. The connector on the truck wire harness side is messed up, and will not clip onto the starter connector anymore. It slips off, and the connection becomes loose. This ends up making the truck not start intermittently. if i get under the truck, and push on the connection, it will then start - so im pretty sure this is my issue. Can anyone out there identify the mating end of this connector on the starter? My truck is a 2004 3500 with Cummins. The starter is new - so it is the wiring harness side of the connector i need to replace.
