Help me identify these e-body bolts #2953412
08/13/21 11:23 AM
08/13/21 11:23 AM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
I think most of them are for the door hinges, but not sure why some are longer than others.
Not sure what the short bolts are for.
Came in a bag full of door hinges, but could be front fender stuff? Rear trunk?
Re: Help me identify these e-body bolts [Re: 2fast4yourBrain] #2953533
08/13/21 06:20 PM
08/13/21 06:20 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Bumper brackets to body bolts maybe for some of them?
Re: Help me identify these e-body bolts [Re: Neil] #2953547
08/13/21 07:13 PM
08/13/21 07:13 PM
N.E. OHIO
P
polara426 Offline
polara426  Offline
P
N.E. OHIO
Been awhile but those look like fender bolts and brackets. The stud should go bottom of dog leg.
Re: Help me identify these e-body bolts [Re: polara426] #2953560
08/13/21 08:14 PM
08/13/21 08:14 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
top row looks like door hinge bolts ? 3/8" thread , 9/16" hex ?
2nd row down left to right 1/4-20 could be header to fender or valance to fender bolts ,,,,next 1/4-20 sems screw has 3/8" hex head with fixed washer head exhaust muffler heat shield ,, same as rear axle to frame rail bumper , the 2 on far right - front bumper bracket to frame rail bolts ?
3rd row down - left to right - the single one ,,,maybe same as above it , the pair on far right, No idea
4th row down , stud with the nut and captive washer is lower fender to rocker panel stud
Re: Help me identify these e-body bolts [Re: 2fast4yourBrain] #2954362
08/16/21 05:10 PM
08/16/21 05:10 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
The square, plastic / nylon items are used on the trunk's torsion rods.
Re: Help me identify these e-body bolts [Re: 2fast4yourBrain] #2954408
08/16/21 06:44 PM
08/16/21 06:44 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Four pointy ones towards the middle appear to be away bar bracket screws that go into the frame.
If you send me the head size and length I can look them up in my resto book
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
