David Visard on exhaust and mufflers #2951956
08/09/21 08:26 AM
08/09/21 08:26 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I watched this and it gives some guidance to flow so you don't lose hp.
Re: David Visard on exhaust and mufflers [Re: Clanton] #2952022
08/09/21 11:58 AM
08/09/21 11:58 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Same exact info as he covered in this book 11 years ago. Even the pics and graphs are the same.
Re: David Visard on exhaust and mufflers [Re: GomangoCuda] #2952046
08/09/21 01:37 PM
08/09/21 01:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
We all need a reminder after some time about info we have read he just dragged it out too long in the video to get to the point.
Re: David Visard on exhaust and mufflers [Re: Clanton] #2952067
08/09/21 02:53 PM
08/09/21 02:53 PM
GomangoCuda Offline
GomangoCuda  Offline
He really needs to have a script to keep him on track instead of just winging it.
Nobody sells that expansion box. I bet he has an ironclad patent on that after Walker got him on the Super Turbo muffler.
Re: David Visard on exhaust and mufflers [Re: GomangoCuda] #2952126
08/09/21 05:45 PM
08/09/21 05:45 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The expansion box or boxes is the least of the problem.
Re: David Visard on exhaust and mufflers [Re: GomangoCuda] #2952322
08/10/21 07:46 AM
08/10/21 07:46 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Would a Hooker Aerochamber muffler work (the center inlet, center outlet version)?
Re: David Visard on exhaust and mufflers [Re: DGS] #2952325
08/10/21 08:09 AM
08/10/21 08:09 AM
pennsylvania
poboyengineering Offline
pennsylvania
The design looks good, but does it have enough volume?
And does the perforated opening affect the "open air" signal that the chamber mimics?
Me thinks not. The drawing looks pretty simple, a little math to figure the dimensions and an afternoon with
a welder and Bob's your uncle.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: David Visard on exhaust and mufflers [Re: DGS] #2952326
08/10/21 08:10 AM
08/10/21 08:10 AM
an8sec70cuda Offline
All I can tell you is those Aerochamber mufflers are nice! They sound good and make good power. Right in the ballpark of a straight through Dynomax Ultraflow and WAYYYY better than the super restrictive Dynomax Super Turbo.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: David Visard on exhaust and mufflers [Re: an8sec70cuda] #2952339
08/10/21 09:17 AM
08/10/21 09:17 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The expansion box is a piece of cake. For a 526 c.i. stroker I calculated a box 4" high x 10" wide by 14" long per side. Then into the muffler. Trouble is the expansion box eats up all the stock muffler location.
Re: David Visard on exhaust and mufflers [Re: an8sec70cuda] #2952357
08/10/21 09:56 AM
08/10/21 09:56 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I had those on my dad's chevelle. Very nice low mellow tone. I use Hooker Max flow's on my Barracuda. No real testing, but they are quit til ya hammer on it, then just the sound of badass muscle.
Re: David Visard on exhaust and mufflers [Re: Clanton] #2952358
08/10/21 09:59 AM
08/10/21 09:59 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Just some pics from the video to help.
Re: David Visard on exhaust and mufflers [Re: Clanton] #2952359
08/10/21 10:01 AM
08/10/21 10:01 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
2
Re: David Visard on exhaust and mufflers [Re: Clanton] #2952372
08/10/21 10:26 AM
08/10/21 10:26 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My brother has aero chambers on his car, and it runs very close to the same times so he just leaves them on when he races. Not worth the effort to remove them after driving the car to the track.
Re: David Visard on exhaust and mufflers [Re: Neil] #2952457
08/10/21 01:24 PM
08/10/21 01:24 PM
moparx Online content
moparx  Online Content
that was an interesting video by mr visard for sure ! bow thank you for posting ! up
beer
Re: David Visard on exhaust and mufflers [Re: moparx] #2952473
08/10/21 02:06 PM
08/10/21 02:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When it comes to a street car, many things are more trouble than they're worth. You build a 550 hp motor but the mufflers you use kill 25 hp. Will you really ever notice that ?!?! And was your combo optimal to begin with, with parts that are designed to work together or did you opt for something like a tunnel ram just because you liked the looks.
Truthfully, building the optimum system such as Mr Vizards's would be a real pain in the ass and expensive. Assuming everything is carefully chosen right down to the headers, you now have to optimize the collector tubes to the custom expansion box(es). Then find mufflers that flow the necessary CFM. Then there's the issue of fitting all this under the car. Well congratulations. Now someone with a bigger cam comes along and kicks your ass.
Its nice to see all this research but applying its is quite another matter.
Re: David Visard on exhaust and mufflers [Re: Stanton] #2952477
08/10/21 02:32 PM
08/10/21 02:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
So with all that negativity do you know if it would fit on anyones car?The example in the pic with full exh is a 600hp Vette.I am just making conversation.Here is an exhaust pipe calculator if you want to use it. exh calc
Re: David Visard on exhaust and mufflers [Re: Clanton] #2952563
08/10/21 05:58 PM
08/10/21 05:58 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Old stuff my 1973 Bultaco had one cylinder 1-3/4 header and then the expansion chamber (tapered up to 4-1/2) then outlet pipe was maybe 1-1/8
Re: David Visard on exhaust and mufflers [Re: cudaman1969] #2952639
08/10/21 09:01 PM
08/10/21 09:01 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
They did a muffler Dyno shootout in a local magazine many years ago, the Hooker Aero Chamber was the best for both power and torque. This was probably 25 years ago
There was a straight through Magnaflow muffler that was quite popular as well, do they still exist?
Alan Jones
Re: David Visard on exhaust and mufflers [Re: Stanton] #2961141
09/05/21 06:42 AM
09/05/21 06:42 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Come on,you know better than this.
Lets ignore that 25 hp loss,and while we are at it lets leave that stock aircleaner on their,and yeah i know we dont need that roller cam either that gives us alitle more power,and surely we dont need those few hp we get from that aftermarket intakemanifold and,that big old holley is not worth the trouble either so lets keep that that stock carter 600cfm thingy,and why would anyone care to put headers on their car,its just a few hp anyway so lets keep those old manifolds,they tend to fit better anyway,and why on earth would anyone botter to actualy put the effort into get that timingcurve right?
Yeah at this point you are pretty much back to a stock engine,just because we didnt bother for those last 25 hp in a bunch of places....
Re: David Visard on exhaust and mufflers [Re: 1Fast340] #2961167
09/05/21 09:31 AM
09/05/21 09:31 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Interesting vid,I also have the hooker aerochamber mufflers. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
