Should I balance my slicks???
#295144
04/21/09 01:20 PM
04/21/09 01:20 PM
mikemotorhead
super street
super street
Re: Should I balance my slicks???
[Re: mikemotorhead]
#295147
04/21/09 01:37 PM
04/21/09 01:37 PM
Challenger 1
Cincinnati, Ohio
The old timers at the track say it is not necessary because when the tire distorts at speed that the balance weights will not keep the tire balanced? I still have them balanced but it got me to thinking
I've been through at least 10 pair of slicks that we mounted and have never balanced them. We would mount them right in our pits(beadlocks) and then go run 260 MPH without any trouble. No they don't need to be balanced, I'm sure. I'm talking racing slicks only.
[Re: RemCharger]
#295149
04/21/09 01:45 PM
04/21/09 01:45 PM
Quicktree
Is one better than the other? Well I've never heard someone say that something unbalanced works better than balanced. If nothing else, you get more even tread wear, and save your shocks from having to do unnecessary work. I do my own, but if I couldn't , I'd still pay the few bucks.
have you ever tried to balance something round then D shape it.? the tire is not round going down the track, so how does balancing it help anything?
[Re: mikemotorhead]
#295150
04/21/09 01:52 PM
04/21/09 01:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I will continue to balance mine.... if you ever seen one really out of balance the car can jump off the track.... the pros do it for a reason
[Re: Quicktree]
#295151
04/21/09 02:05 PM
04/21/09 02:05 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Couple of reasons. Just unbalanced turns into really unbalanced. But balanced turns into a bit un balanced. Also, If your rims are out, they do not go d shaped. Kind of a "lemons, make lemonade" deal.
[Re: RemCharger]
#295153
04/21/09 02:06 PM
04/21/09 02:06 PM
Quicktree
I understand, I have done it both ways and couldn't tell the difference. key is getting a good set of slicks.
[Re: Quicktree]
#295155
04/21/09 02:24 PM
04/21/09 02:24 PM
Challenger 1
Cincinnati, Ohio
Oh yea, we would measure roll out after mounting. If there weren't matched, back they went to GY or Hooiser. Once you know your rims are good, your good. IMO
[Re: Mr.Yuck]
#295156
04/21/09 02:24 PM
04/21/09 02:24 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
I have never balanced my rear tires,and have street driven and raced it with zero issues over the years,Hoosier qtp's
I have always ran tubes, dont know if that makes any difference.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B G Racing]
#295158
04/21/09 02:27 PM
04/21/09 02:27 PM
Challenger 1
Cincinnati, Ohio
What can it hurt,
I never liked the stick on weights(beadlocks) When they come off it could hurt someone or something.
[Re: Challenger 1]
#295159
04/21/09 02:32 PM
04/21/09 02:32 PM
MR_P_BODY
What can it hurt,
Mine are on the inside of the rim and tape over the weights.... never had one come off
[Re: mikemotorhead]
#295163
04/21/09 05:50 PM
04/21/09 05:50 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I had a set of slicks that shook so hard at the 1000 foot that I couldn't see out of my eye glasses. A quickie bubble balance job is all it took to correct.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
