Over reving a motor-what likely to suffer? #295135
04/21/09 01:14 PM
04/21/09 01:14 PM
mikemotorhead Offline OP
super street
super street
I have a MSD and have a high end rev limiter but I know a few guy's at the track that do not have any high end protection. What parts is it likely to hurt the most if they "Go to the Moon"!
Re: Over reving a motor-what likely to suffer? [Re: mikemotorhead] #295136
04/21/09 01:20 PM
04/21/09 01:20 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
valve float which could cause a collision between them and the pistons ...
Re: Over reving a motor-what likely to suffer? [Re: JohnRR] #295137
04/21/09 01:24 PM
04/21/09 01:24 PM
united kingdom
blown360 Offline
blown360  Offline
united kingdom
Yep and if real unlucky that'll result in bent pushrods,damaged rocker arms damaged heads the list goes on and on.....
Re: Over reving a motor-what likely to suffer? [Re: blown360] #295138
04/21/09 01:35 PM
04/21/09 01:35 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
How about rod and bolt stretch? Your piston can end up weighing 10,000 pounds plus depending on weight and rpm.
Post deleted by Defbob [Re: RemCharger] #295139
04/21/09 01:38 PM
04/21/09 01:38 PM
Re: Over reving a motor-what likely to suffer? #295140
04/21/09 01:42 PM
04/21/09 01:42 PM
united kingdom
blown360 Offline
blown360  Offline
united kingdom
Basically unless your into throwing money away run some kind of limiter! Fair play you might get away with it once but the next time you wont be so lucky!
Re: Over reving a motor-what likely to suffer? [Re: blown360] #295141
04/21/09 03:07 PM
04/21/09 03:07 PM
NC
440Jim Offline
440Jim  Offline
NC
Add to the list killing the valve springs. Which will make later runs float earlier and hurt more things if the first "attempt" didn't do worse.
Re: Over reving a motor-what likely to suffer? [Re: 440Jim] #295142
04/21/09 06:30 PM
04/21/09 06:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's what get's hurt the most is valve springs.
Re: Over reving a motor-what likely to suffer? [Re: Challenger 1] #295143
04/21/09 06:34 PM
04/21/09 06:34 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I did it many times "back in the day" with stock shifters, missing 3rd and shifting into N, as stated before, pistons get some smiley faces on them, exhaust valves all get bent and have to come out.
