Re: 727 TF clean or safe neutral?
[Re: lancer493]
#2951048
08/06/21 12:53 PM
08/06/21 12:53 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
727 Specialist http://www.727specialist.com/ offers: 12-22G25SN Trans Brake Safe Neutral Feature Available Band on or off in low gear Allows for safe disengagement by keeping rotating parts under control on the other end Altered shift pattern - PN123N For cars with aluminum rods that need to be shifted out of gear into neutral at the end of the quarter to take off the strain the rods during deceleration.
[Re: J_BODY]
#2951388
08/07/21 02:14 PM
08/07/21 02:14 PM
John_Kunkel
Rio Linda, CA
As per the OP, we need to differentiate between "clean Neutral" and "safe Neutral".
Clean Neutral:
An extra Neutral position after 3rd that release all bands and clutches and prevents compression braking during deceleration.
Safe Neutral:
A Neutral position after 3rd that releases bands and clutches except the front drum. This prevents over-speed of front drum.
