Re: Need 1974-80 Ramcharger liftgate lock
[Re: Hugh Jorgan]
#2950378
08/04/21 01:34 PM
08/04/21 01:34 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The door lock key is the same as the hatch lock key right? Can't you remove the door lock and take it to a local locksmith to have replacement keys made and save on a service call? If that's still too expensive, maybe start a go fund me here on moparts. I'll send a buck to help. No the key is not the same. It is not even a Mopar style.
[Re: migsBIG]
#2950720
08/05/21 01:52 PM
08/05/21 01:52 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
It should still open from the inside with the lever that has the black plastic piece on it. I'm 99% sure they are the same as Travel Trailer and some RV locks.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: NITROUSN]
#2950725
08/05/21 02:18 PM
08/05/21 02:18 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
The door lock key is the same as the hatch lock key right? Can't you remove the door lock and take it to a local locksmith to have replacement keys made and save on a service call? If that's still too expensive, maybe start a go fund me here on moparts. I'll send a buck to help. No the key is not the same. It is not even a Mopar style. It's an AMC key blank. Too bad this didn't come up earlier, I just found my original Ramcharger keys with the tag and threw them out. I sold that truck 25 years ago.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2950789
08/05/21 05:58 PM
08/05/21 05:58 PM
NITROUSN
The door lock key is the same as the hatch lock key right? Can't you remove the door lock and take it to a local locksmith to have replacement keys made and save on a service call? If that's still too expensive, maybe start a go fund me here on moparts. I'll send a buck to help. No the key is not the same. It is not even a Mopar style. It's an AMC key blank. Too bad this didn't come up earlier, I just found my original Ramcharger keys with the tag and threw them out. I sold that truck 25 years ago. It is not an automotive key blank.
[Re: 3hundred]
#2951311
08/07/21 09:54 AM
08/07/21 09:54 AM
Posts: 76 South East Ontario, Canada
Ramtough
The door lock key is the same as the hatch lock key right? Can't you remove the door lock and take it to a local locksmith to have replacement keys made and save on a service call? If that's still too expensive, maybe start a go fund me here on moparts. I'll send a buck to help. No the key is not the same. It is not even a Mopar style. It's an AMC key blank. Too bad this didn't come up earlier, I just found my original Ramcharger keys with the tag and threw them out. I sold that truck 25 years ago. 81 and newer is a like a AMC key, 80 and older like a universal RV, tool box key.
[Re: Ramtough]
#2951337
08/07/21 11:29 AM
08/07/21 11:29 AM
3hundred
Colleyville
The door lock key is the same as the hatch lock key right? Can't you remove the door lock and take it to a local locksmith to have replacement keys made and save on a service call? If that's still too expensive, maybe start a go fund me here on moparts. I'll send a buck to help. No the key is not the same. It is not even a Mopar style. It's an AMC key blank. Too bad this didn't come up earlier, I just found my original Ramcharger keys with the tag and threw them out. I sold that truck 25 years ago. 81 and newer is a like a AMC key, 80 and older like a universal RV, tool box key. Thank you, I guess it's been so many years since I had one, I'd forgotten. I just recall the AMC ignition key blank for the liftgate. Then sometime they went to one key for everything.
[Re: migsBIG]
#2963504
09/13/21 08:27 AM
09/13/21 08:27 AM
Posts: 4 usa
ShaneHobbs
usa
That work can easily be handled by local locksmith experts also.
