Clutch for procharged 540
#2949893
08/03/21 02:25 AM
08/03/21 02:25 AM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
Hi Fellas So, I’m building a 528/540 stroker on a Callies 440 block, trickflow 240 heads, ProFlo XT4 MPFI forward facing intake with at this stage an F-2 Procharger aim is NA 600hp, 15psi for around 1100 hp there about’s roughly, I have a TREMEC TKX and Dana in a 1970 RR. Question is,,,,,, flywheel, clutch and bell housing, what to get???? This car is basically a street bruiser, rarely see drag strip use apart from the odd street day. Will I absolutely need a scatter shield type bell housing or will one of the aftermarket alloy ones be ok, Centreforce make some fine looking clutch/flywheel assemblies, SST do a nice single plate unit.
What’s the general consensus out there please???
Re: Clutch for procharged 540
[Re: crash520]
#2949895
08/03/21 05:14 AM
08/03/21 05:14 AM
Posts: 912 London, England
mopar_mark
London, England
In addition to the 1,100 HP, your engine combo will also produce tons of torque. I personally would go with a Scatter Shield Bell housing…. Just to give me peace of mind for when I did rag the nuts off it on the street or occasional strip use. 😋
[Re: crash520]
#2949901
08/03/21 06:41 AM
08/03/21 06:41 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
QuickTime bellhousing and a twin disc Centerforce. Turbo Vette guys seem to like them. I'd suggest contacting Brewers and or a couple clutch/transmission shops to get a better recommendation based on other cars roaming around with boost...
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2949903
08/03/21 06:50 AM
08/03/21 06:50 AM
Posts: 10,039 MN
JERICOGTX
MN
i would call Cale Aronson at Black Magic Clutches, and see what he can do for you. I prefer the Lakewood Scattershield over the Quick Time. More room in the can. We had a issue with clearance in HEMI Joel's car, and the counterweights were rubbing the inside of the can.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2949918
08/03/21 08:22 AM
08/03/21 08:22 AM
Posts: 656 Florida
CJD AUTOMOTIVE
The TKX is not rated to take that power. A Magnum isn't either. A Magnum with a PPG gear set will. The newer Tilton ST-246 twin disc are what we have been using in street/autoX, and trackday builds.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: crash520]
#2949941
08/03/21 09:50 AM
08/03/21 09:50 AM
Posts: 4,209 New York
polyspheric
New York
Calculation is?
Boffin Emeritus
[Re: crash520]
#2949961
08/03/21 11:01 AM
08/03/21 11:01 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Any clutch that will manage to hold that kind of HP and torque will eventually shred the teeth off the gears in that transmission. I suggest an adjustable unit that you can drop the base pressure down at the track when whooping it. A sintered iron disc with a Long style PP would get the job done but will probably be close to $2500-3000 with a good steel can. I know of a Tim Hyatt clutch that would probably work but will need a new disc installed to make it work with your combo. She may even still have the Lakewood can as well. I can send her a text if you are interested. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#2949975
08/03/21 11:38 AM
08/03/21 11:38 AM
Posts: 4,457 Washington
madscientist
Washington
You need to stop and reconsider what you are doing. Doesn’t matter what clutch you have that transmission won’t live. Call G Force and have them sell you a transmission. Then, call Cale at Black Magic Clutches or Rob at Advanced Clutches and TALK to them. Let them hook you up. The very last thing you need for a clutch is some junk [censored] twin disc street clutch. And while I’m thinking about it, no matter what scatter shield you get, have a window out in it so you can tune the clutch. If you aren’t willing to do all of that you need an automatic.
[Re: RATTRAP]
#2950037
08/03/21 02:51 PM
08/03/21 02:51 PM
Posts: 10,039 MN
JERICOGTX
MN
HYATT RACING FOR YOUR CLUTCH AND BELL HOUSING They will also put a window in the bell so you can adjust the clutch and recertify it Tim passed away about 5 years ago. I heard his son was taking over the business after that, but have not heard anyone going through them in years.
69 GTX
68 Road Runner
[Re: AndyF]
#2950070
08/03/21 04:31 PM
08/03/21 04:31 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Good luck and hope you have a fat wallet because you're going to be breaking parts for a long time. You should probably just switch to a very heavy duty automatic now before you spend $10,000 on busted transmissions and burned up clutches. What he said...
[Re: JERICOGTX]
#2950078
08/03/21 04:51 PM
08/03/21 04:51 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
HYATT RACING FOR YOUR CLUTCH AND BELL HOUSING They will also put a window in the bell so you can adjust the clutch and recertify it Tim passed away about 5 years ago. I heard his son was taking over the business after that, but have not heard anyone going through them in years. I don't think its been 5 years since I bought mine from Hyatt Racing, It was brand new and certified in 2018
