I need some OBD1 help. Fuel is EXTREMELY rich
#2948702
07/30/21 12:05 AM
07/30/21 12:05 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Ok folks, I need a little advice on the codes my 92 5.2 is throwing.
Its flashing the 27 code twice. I've never seen this happen before.
I have been chasing a code 27 issue for a while, and up until today it has only flashed 27 once in the series.
First question is why is it flashing the same code twice?
Now on to what lead up to the code reading today.
Today I believe that I had an injector or two stick open. It was running extremely rich, enough so that it was hazing out the tailpipe and would burn your eyes, and didn't want to idle.
Of course it happened 25 miles from home, so I limped it home running like crap and praying it didn't strand me in the 103° heat out in the middle of nowhere.
Previously (about a year ago) I had found a couple bad injector connectors (the previous code 27 issue I had) and have those fixed. Its not the ECU my spare ECU throws the same code when on this truck. The NOID lights say the injectors are all getting the signal to fire. I checked that today after I made it home.
Perhaps there's some crap stuck in an injector or two? Or maybe just worn out?
I came across an older post on a Dakota forum on the internet, and others with the same symptoms had been able to fix it with an injector change. This was usually after several other parts, TPS, IAC, MAF etc had been swapped. I did change the TPS, and IAC a couple years ago for a different issue with the idle surging when the engine was cold.
I am trying to decide if it's time to delete the MPFI on this 5.2, or do I spend a couple hundred on new injectors?
I will say up front I am a novice when it comes to dealing with fuel injection. So I honestly don't know what to look for to check an injector for proper functionality.
If putting a set of injectors into it is the correct option, is there a better injector than symtock? I run a Mopar Performance ECU is there a performance injector that would compliment the ECU?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: I need some OBD1 help. Fuel is EXTREMELY rich
[Re: varunner]
#2948733
07/30/21 07:58 AM
07/30/21 07:58 AM
Posts: 6,291 nowhere
Sniper
nowhere
I think you need to try to figure out which cylinders are rich. You might pull all the plugs are see what they look like. Is this a stock engine ? It's a TBI engine so looking at plugs might tell it's rich but it won't be cylinder dependent. Pull the air cleaner, look down the throttle body and have someone turn the key on, but don't start. a leaky injector will be obvious.
[Re: varunner]
#2948934
07/30/21 07:15 PM
07/30/21 07:15 PM
hp383
State of Confusion
I talked to my son, who's a master diagnostic tech. He said most of the time when a fuel injected motor is way rich, look at MAF sensor, o2 sensor, or fuel pressure regulator. Still could be injectors though. Tell us what you find. I will do some checking. Can the MAF sensor be checked? I have a fuel pressure tester, so checking pressure at the rail shouldn't be an issue. The O2 sensor will usually trigger its own CEL, but I can try to get someone to help me get to it.
[Re: hp383]
#2948993
07/30/21 10:00 PM
07/30/21 10:00 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
When reading the codes on the dash display, the codes are very generic and most of them cover multiple, more detailed codes. For example, you might have an O2 code, but it could be the heater circuit or the sensor itself (out of range, rich or lean). That is likely why you are seeing the code twice. You really need to hook it up to a scan tool.
And, my personal opinion is that would NEVER take injection off an engine to go carb, even if I took my 5.9 Magnum and put it in an older car that didn't need a smog check.
[Re: hp383]
#2949003
07/30/21 10:22 PM
07/30/21 10:22 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I talked to my son, who's a master diagnostic tech. He said most of the time when a fuel injected motor is way rich, look at MAF sensor, o2 sensor, or fuel pressure regulator. Still could be injectors though. Tell us what you find. I will do some checking. Can the MAF sensor be checked? I have a fuel pressure tester, so checking pressure at the rail shouldn't be an issue. The O2 sensor will usually trigger its own CEL, but I can try to get someone to help me get to it. It doesn't have a MAF, it's a speed density system. A couple things on these, the fuel purge hose can get soft and deteriorate at the throttle body as well as the vacuum hose elbow for the MAP sensor creating vacuum leaks. I have also seen where the coolant temp sensor wires insulation down by the thermostat housing will also deteriorate and crumble off. This shorts the wires together and the computer thinks it's -40° causing a very rich condition.
[Re: hp383]
#2949044
07/31/21 05:34 AM
07/31/21 05:34 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The Actron Scantool with the Chrysler cartridge does a reasonably good job of letting you watch OBD-I operation in real time. After using it for some time I cannot imagine troubleshooting without it on my 1995 OBD-I Magnum 5.9 V8. This one on ebay only has the GM cartridge https://www.ebay.com/itm/284384762128?hash=item4236a71910:g:ETkAAOSw6jdg~ZcxNow days the official Chrysler dealership scan tools show up on ebay from time to time. There are two coolant temperature sensors on the OBD-I so the one your dash gauge is reading can be different than what your PCM computer thinks the coolant temp is. The maze of vacuum plastic miniature hoses at the back of the engine definitely gets brittle with age and can create weird problems with the EGR. If your EGR valve is original it is near certain that the valve seat has corroded away letting exhaust flow all the time causing rough running or miss fires at idle. On a 1995 the wire insulation and even the fuel line plastic covering is “tasty” to rodents and squirrels, do not ask me how I know......
[Re: Moparite]
#2949149
07/31/21 01:35 PM
07/31/21 01:35 PM
Posts: 19,534 north of coder
moparx
speaking of the coolant temperature sensors, the bulb in the coolant can get "green" deposits on the brass, effectively insulating it, making it think it's "-40" as has been mentioned. cleaning it up to a nice brass finish like it was when new, will often times make it work like it should. just sharing my experience playing with this stuff over the many years.
[Re: Moparite]
#2949219
07/31/21 06:28 PM
07/31/21 06:28 PM
Posts: 4,956 WI
Dcuda69
WI
27 is a generic injector fault code, You need to the "P0" code that will tell you witch cylinder has the injector issue. Take it to one of the parts stores that will read codes for free. Also you can pull the plugs and see what they look like that may give you a clue. There will be no "PO" codes on an OBD I vehicle
[Re: Dcuda69]
#2949318
08/01/21 08:52 AM
08/01/21 08:52 AM
Posts: 1,007 rust belt
Moparite
rust belt
There will be no "PO" codes on an OBD I vehicle Yeah, Your right. If it was a OBD2 then you could get individual injector codes.
