Portable Generator #2948309
07/28/21 09:06 PM
07/28/21 09:06 PM
Hunt Valley, Maryland
1fastrunner Offline OP
We have purchased a 9000 watt generator to run some items during a power outage. We have gotten estimates from two electric companies so far and they are doing it different ways.
The first one gave us a higher quote but is adding a additional panel. We currently have 2 200 amp panels for our house. he told use we could pick 10 switches for the new panel and he was using a 50 amp circuit to the generator.
The second one wants to keep the 2 panels and run a 30 amp interlock off each panel into another interlock switch to the generator and said we could turn off the high circuits and use the lights and stuff in the house as needed. This was much less expensive.
Money is not our deciding factor as we want it dome the right way. If both are good, is there any information that would help us decide?
Thanks,
Re: Portable Generator [Re: 1fastrunner] #2948330
07/28/21 09:39 PM
07/28/21 09:39 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
On mine, the electrician just mounted a box on the house near the generator, and put an interlock on my existing panel.
I think the whole deal was a couple hundred bucks.
Oddly, my well pump runs off a separate box (main house service), which I didn't know at the time.
So, even if the gen is supplying the house, it's "after" the well pump.
Not a big deal for me, though I wish I'd known that; I just keep water (5-gal bucket) to refill the toilet and keep a few gallons of drinking water.
My main service would be a pain to get to in a decent snowstorm anyway,
Re: Portable Generator [Re: topside] #2948413
07/29/21 08:44 AM
07/29/21 08:44 AM
Andrewh Offline
Andrewh  Offline
The first guy should also have an interlock but you didn't say.
how I would want it run would be
3rd panel with an interlock between the genset and main panel.
Everything on the 3rd can be run by the genset.
1 of the mains feeds the 3rd panel and you can't have both the genset and mains powered on the 3rd panel. Ie the interlock on the 3rd panel.
the other 2 mains stay on city power full time.
a few reasons.
only 1 interlock to deal with.
no mistakes on leaving too many things hooked to the genset.
can tell when city power is back on.
Re: Portable Generator [Re: Andrewh] #2948440
07/29/21 10:09 AM
07/29/21 10:09 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would add a small panel between the meter and the two other panels with an interlocking breaker.
Sounds like you are smart enough to manage the loads without restricting yourself to ten circuits.
I have a "smart" meter at my house and I can look at it and tell if I have utility power or not.
Re: Portable Generator [Re: Andrewh] #2948442
07/29/21 10:13 AM
07/29/21 10:13 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Portable generator? Or is this a fixed location for a residence? 9 KW is about 50 amps, hence the 50 amp breaker for the generator feeder. For my money I'd regroup your critical loads into a new panel making sure you don't overload the generator. I'd then use one transfer switch in the feed to that panel so that when a power loss occurs, your critical loads are switched from your utility to the generator. Your first option sounds a lot like this and is the one I'd go with.
Re: Portable Generator [Re: 6PakBee] #2948510
07/29/21 12:49 PM
07/29/21 12:49 PM
This is a portable generator, the cost difference between to 2 is about $1,800. I don't mind paying the r
higher price , but if the other option would work? It's just 2 of us in the house, our well pump and minimal electricity is all we will need.
Re: Portable Generator [Re: topside] #2948525
07/29/21 01:23 PM
07/29/21 01:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The well pump is run separately so you can fight a fire if your house (panel) is burning. Probably for an equal amount of time you are more likely to burn your house down during a power outage (using candles, too much power for the generator...) and even if they were the same risk you still want to have your water to fight a fire, so it would be a good idea to do something about it. I have a slow well (2GPM) and an 1850 gallon cistern, I like having a gasoline powered pump handy to pump right out of the cistern in a total loss of power.
Re: Portable Generator [Re: HotRodDave] #2948617
07/29/21 06:03 PM
07/29/21 06:03 PM
My well isn't run separately as I have a 500 gallon tank with a pump for my sprinkler system. Not sure how that would work during a fire that may affect my electricity not to mention during a power outage.
I am still trying to decide. I have emailed the electrician wanting to add a third panel about doing it the other way. In the meantime, any input would be appreciated.
Re: Portable Generator [Re: 1fastrunner] #2948650
07/29/21 08:11 PM
07/29/21 08:11 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Factor in if you have electric a/c, water heater, heat pump/base board heat, think about the seasons and what you use as well during said season, year round. In my mind, thats what a generator should handle. Anything you use normally so you don't have to wander from your normal. An extra fridge, an extra freezer, over build so you don't get caught crying.
Re: Portable Generator [Re: moparjim79] #2948651
07/29/21 08:14 PM
07/29/21 08:14 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Also if you over build, if you ever sell the house, it will be a great item of leverage in negotiating price if you can show you stand independently from the grid during an outage. I know I would pay for that insurance
Re: Portable Generator [Re: 1fastrunner] #2948652
07/29/21 08:15 PM
07/29/21 08:15 PM
N
NITROUSN Offline
NITROUSN  Offline
N
First question to the OP why two 200 amp panels? If it was me I would run a bigger generator and an automatic transfer switch. I was looking at a 20kw setup. Generator is big enough to run everything. Sometimes a smaller generator may use just as much fuel as a larger unit.
Re: Portable Generator [Re: NITROUSN] #2948659
07/29/21 08:30 PM
07/29/21 08:30 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My neighbor has a whole house generator that runs on natural gas. It comes on every Sunday to run for awhile. Power goes off it automatically starts.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Portable Generator [Re: HotRodDave] #2948740
07/30/21 08:15 AM
07/30/21 08:15 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just be careful, this past winter we had a multiday electrical outage so I drug out the portable generator, it's a generac. Went to put fuel in the tank and it was full of rust. I had only ever ran it once when I first bought it and I put it way empty and sealed. That is not the time to find out your portable generator, or fire fighting pump, will not work. In my case I ended up using fabbing a temporary gas tank by using a plastic one, putting a nipple in the bottom and adding a long fuel hose. Tied it all down with a bungee cord. Looking for a good plastic replacement for the original metal one.
Re: Portable Generator [Re: 1fastrunner] #2948783
07/30/21 10:54 AM
07/30/21 10:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
For those of us that have generators for standby use at our homes, we need to drag them out every thirty days or so and run them, preferably under load.
I shoot for 30 days, probably make 60 and run my generator with an electric heater hooked up.
This is really the only way you know its going to work when you need it.
Data centers will typically run their generators without load once a week and under load once a month.
Re: Portable Generator [Re: 340Cuda] #2948830
07/30/21 01:27 PM
07/30/21 01:27 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Good advice, which I also fail to follow on a regular basis laugh
When sizing a generator, keep in mind that a large one will use considerably more fuel than a small one, even when lightly loaded. If you just have 500 watts of lights and TV on, the whole-house unit will be expensive to operate.
I have a remote-start 2.5 kw Onan in a hut the size of a large doghouse with two 6-gal. outboard motor tanks. It will run lights, TV, furnace, and my CPAP machine and sips fuel... the thirsty 10 kw Onan rarely is needed except to recharge the well tank and run the water heater. twocents
Re: Portable Generator [Re: DrCharles] #2948971
07/30/21 09:15 PM
07/30/21 09:15 PM
If we had natural gas, we would have a whole house generator. We have propane, so we went with portable. We have a gas stove and a gas fireplace and we are not worried about heat. The well, fridge, kitchen, fireplace fan, and sump pump are all we really need. Anything else is a bonus.
Re: Portable Generator [Re: 1fastrunner] #2949062
07/31/21 08:35 AM
07/31/21 08:35 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Having natural gas service to the house and an existing easy to access port and valve inside the fireplace
has made me think about buying a kit to convert my 10 HP Briggs & Stratton powered Troy built 7500 watt gasoline portable generator to natural gas
and keeping it on hand “just in case.”
If anyone knows the best kit to buy for this please comment.
I have now been through ice storms and Hurricanes that kept the electric service off for more than 7 days numerous times.
Re: Portable Generator [Re: 360view] #2949064
07/31/21 08:44 AM
07/31/21 08:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know of a kit but beware that changing it over to NG will likely reduce its output. Costco was selling a tri fuel generator that ran on Gas, NG, or Propane. It had different output ratings for each fuel, the highest being gasoline and I think proane was next.
68 Barracuda Formula S 340
Re: Portable Generator [Re: Bad340fish] #2949071
07/31/21 09:12 AM
07/31/21 09:12 AM
KY
65pacecar Offline
65pacecar  Offline
KY
If your buying a portable to use for the house as a stand by get an Inverter Generator, often used in the RV world. They produce clean electric that you can run the fridge, TV, router, and other sensitive electronics with, the contractor grade generators will damage sensitive electronics.
Re: Portable Generator [Re: 65pacecar] #2949576
08/02/21 12:55 AM
08/02/21 12:55 AM
Superfreak
Superfreak
And buy a Honda! The small Generac units are absolute garbage, everything vibrates of them and when you need a repair, no one will do it as you can't get parts for them.
