BumbleBee Stripe #2948306
07/28/21 08:54 PM
07/28/21 08:54 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
I am repainting my 70 Challenger RT Vert. I'm going with Plum Crazy with a white gut. I also want to add the "BumbleBee" stripe across the rear of the trunk. Can anyone give me the technical info for the stripe placement. (dimensions, widths, etc.) I'd also need the correct color or paint code for the stripe. 0any other info or advice will be greatly appreciated. Thanx in advance guys
Re: BumbleBee Stripe [Re: 70VERT] #2948319
07/28/21 09:25 PM
07/28/21 09:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Rick Ehrenberg has the factory layout specs for that.
You can contact him here (he's a member) or likely find it in the Mopar Action archives.
Likely one of our members might have the schematic too; I believe it was posted a while back.
Just do a search in the box at upper right for "Challenger bumblebee"...
Re: BumbleBee Stripe [Re: topside] #2948362
07/28/21 11:01 PM
07/28/21 11:01 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
thanks Topside
Re: BumbleBee Stripe [Re: 70VERT] #2948549
07/29/21 02:19 PM
07/29/21 02:19 PM
moparx Offline
moparx  Offline
use the "google search" box at the top. it works way better than just the "search" box.
beer
Re: BumbleBee Stripe [Re: 70VERT] #2948578
07/29/21 04:02 PM
07/29/21 04:02 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 Challenger V9_ stripes were pained before the body color. So spray the whole area, then mask the stripe area off before final paint.
(much less masking this way too)
