Re: which tires less lilely to break parts? Bias or drag
[Re: fig426]
#294700
04/21/09 07:43 AM
04/21/09 07:43 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I assume you mean bias or drag radials? The drag radials are harder on parts. CHIP
[Re: fig426]
#294705
04/21/09 02:08 PM
04/21/09 02:08 PM
an8sec70cuda
A bias tire is more forgiving. A drag radial will make even a 10 sec car go into tire shake like a pro stocker on a poorly prepped track. CHIP
[Re: an8sec70cuda]
#294706
04/21/09 03:16 PM
04/21/09 03:16 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I thought a bias would be just because of it's less rigid construction. I want to put stickier tires on, but don't want to break it either. I'd rather peddle to get it to hook than have so much traction that it breaks.
Randy... You're not going for an axle??
Chris from New Jersey
[Re: fig426]
#294707
04/21/09 06:06 PM
04/21/09 06:06 PM
Posts: 1,890 In the 8's
FY1TA
In the 8's
[Re: cgall]
#294710
04/22/09 02:34 AM
04/22/09 02:34 AM
fig426
East Coast, NJ
What's the rest of the setup? A 12.7 car normally won't break parts, unless it's a 4-speed.
I went 11.4's for 2 seasons with a GM 10-bolt with stock axles and 9" slicks. The key is to never do dry hops, and roll out of the throttle gently when coming out of the water. Never "blip" the throttle for any reason when in gear, it loads/unloads the driveline.
It's a 4 speed
Gary,,,, whatya cryin about? hahahhahaahha
