48* W2 heads on 59* block? #2945858
07/21/21 11:12 PM
07/21/21 11:12 PM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
i have a set of 48* W2 heads and i'm wondering if they will work on my 59* 340 race block? i have done some google searching but most come up 59* heads on 48* blocks
Re: 48* W2 heads on 59* block? [Re: 79410aspenrt] #2945903
07/22/21 05:13 AM
07/22/21 05:13 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Yes they will work, it is just a normal W2 head but the 48° version has pushrod clearance to suit the 48° block tappet layout
Obviously you will need to use rockers for a 59° as the 48° rockers have a lot less offset
Re: 48* W2 heads on 59* block? [Re: GTS340] #2947108
07/25/21 08:18 PM
07/25/21 08:18 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
You will need to machine the heads for pushrod clearance to go to 59*
The 48* version usually ran a Jesel or T&D rocker system, so not sure if they are machined differently for the rocker mounting. The easiest solution would be a set if 59* W2 heads, or something similar like an Edelbrock Victor or Indy head.
Best of luck
Alan Jones
Re: 48* W2 heads on 59* block? [Re: LA360] #2947221
07/26/21 07:55 AM
07/26/21 07:55 AM
Saskatchewan (SK)
Saskatchewan (SK)
i bought the heads complete with 1.6 T&D rockers. the intake face has been machined for the pushrod clearance.
i might put these up for sale and try to find a set of 59* W9's or as you mentioned the Victor or Indy
