Electric A/C ? #2945569
07/21/21 12:29 PM
07/21/21 12:29 PM
GA
roadrunninMark Offline OP
GA
As I am trying to fix my fridge before I have to get a new one, I thought about the way a fridge works and wonder about using that idea in a car. I know it would take some figuring out but the compressor is smaller and could be less draw on the engine? Has anyone thought about trying this? It is just an idea and I don’t think I have the electrical knowledge to try it.
Re: Electric A/C ? [Re: roadrunninMark] #2945582
07/21/21 12:46 PM
07/21/21 12:46 PM
IMGTX Offline
IMGTX  Offline
Fridges use very little compressors, condensers, & evaporators since the air barely circulates and is in a sealed box. Often the circulation inside the fridge is simply convection currents of hot cold air rising & falling. No fan inside at all.
As you increase the size of the box, i.e. Fridge, car, house, store, stadium, more air has to circulate to cool the area.
Small compressors & evaporators will not effectively cool air fast enough to be force blown across the evaporator and through the "box", so the sizing has to increase.
Combine that with the lack of insulation / greenhouse effect of glass windows in cars the size required to cool an area increases.
I believe that an electric AC unit in a car would work. It could be driven by electricity from an alternator and be more efficient BUT it would cost more to produce because while there would be a decrease in AC component costs it would require a sizable increase in electrical capacity and some modifications to the charge system to power the unit at idle. Car companies go for cheap.
I had toyed with the idea of using peltier coolers on a water cooled plate but got sidetracked. It could be a fully contained electric cooler (like they use in micro electric fridges) but I'm sure if it was feasible it would already be done by somebody smarter than I.
Yours is a good idea though, a compressor from a small window unit AC might be the best choice over fridge unit.
Re: Electric A/C ? [Re: roadrunninMark] #2945603
07/21/21 01:12 PM
07/21/21 01:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Modern all-electric and hybrid cars don't have an engine-driven compressor, so the A/C power is all-electric. Why couldn't the system be retrofit into an older car?
Re: Electric A/C ? [Re: John_Kunkel] #2945621
07/21/21 01:44 PM
07/21/21 01:44 PM
Andrewh Offline
Andrewh  Offline
Re: Electric A/C ? [Re: IMGTX] #2945626
07/21/21 01:47 PM
07/21/21 01:47 PM
Andrewh Offline
Andrewh  Offline
Re: Electric A/C ? [Re: Andrewh] #2945641
07/21/21 02:15 PM
07/21/21 02:15 PM
moparx Offline
moparx  Offline
i was thinking about this [https://www.cruisencomfortusa.com/hot-rod-series-1] as well.
i didn't click on the "purchase now" button, but if i remember when this was introduced a couple of years ago, it wasn't exactly moderately priced.
however, in certain applications, it may be the best option. i have never been around anyone that has installed one of these kits, so i have no idea if they work reasonably well or not.
beer
Re: Electric A/C ? [Re: moparx] #2945646
07/21/21 02:24 PM
07/21/21 02:24 PM
GA
GA
A window unit would definitely be easier to convert and cheaper probably. Those that have the knobs still would help.
Re: Electric A/C ? [Re: John_Kunkel] #2945647
07/21/21 02:25 PM
07/21/21 02:25 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I just replaced the compressor on an 07 Civic hybrid. it is both engine drive and electrically driven, depending on what mode it is operating in. The compressor is also not cheap.
Re: Electric A/C ? [Re: moparx] #2945684
07/21/21 04:13 PM
07/21/21 04:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
You had better have a healthy system before installing one of them. 38-46 amps nominal @ 12 Volts
Re: Electric A/C ? [Re: roadrunninMark] #2945732
07/21/21 06:41 PM
07/21/21 06:41 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have often looked at the PTO option on some of the 1994+ 2500/3500 Dodge Ram trucks and thought something like:
“If I had one of those PTO’s hooked to a 3 phase 120/240 generator,
I would not only have a portable electrical generator station,
I would also have a “DYNO” to test the engine fuel economy at various % throttle and rpms.
Just generate and measure the electrical power fed to a resistance heater.
I could predict ahead of time what MPG could be got with various gear ratios, because I can calculate aerodynamic and tire rolling resistance power.
Reading this post I can now add:
You could add more air conditioning options for the truck cab too.
Use the PTO/generator to supply power
to one of the “portable room air conditioners” with a single hot air outlet house.
(drain the condensate water through the floor of the truck cab.)
Another factor to consider:
if the portable air conditioner developed a fault,
quickly swap it out as a module.
Wouldn’t it be interesting if each “system” in a truck/car
was a “quick swap module” if it was not too expensive?
The Hubble Space Telescope is a collection of modules
( except for the faulty Perkins-Elmer built main reflecting mirror,
which should have been instead the correctly polished Corning Glass Company mirror, which NASA bought, paid for, and put in a warehouse... no kidding)
Re: Electric A/C ? [Re: 360view] #2945880
07/22/21 01:05 AM
07/22/21 01:05 AM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
I have experience using a portable 120 volt a/c unit to cool a large machine cab. The hydraulic driven air conditioner was in a back corner and did not blow any air on the operator. The machine had a large generator and a 120 volt outlet in the cab. The portable a/c unit made all the difference. No more complaints from the operator! Also the portable a/c required no maintenance. I can't say the same for the hydraulic unit.
Re: Electric A/C ? [Re: NITROUSN] #2946005
07/22/21 12:15 PM
07/22/21 12:15 PM
moparx Offline
moparx  Offline
beer
absolutely ! iagree it would be interesting to see the installation sheet for this, and if they mention a minimum alternator size needed, as well as any needed mods to the electrical system.
beer
Re: Electric A/C ? [Re: NITROUSN] #2946359
07/23/21 01:32 PM
07/23/21 01:32 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
More than that if you want any sort of cooling performance. I think my portable 12,000 BTU unit at home is rated at 10 or 12 amps running. That means 100-120 amps at 12v.
Re: Electric A/C ? [Re: DaytonaTurbo] #2946369
07/23/21 01:48 PM
07/23/21 01:48 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
It's what we use in a lot of Cessna aircraft. Looks just like an automotive rotary pump driven by an electric motor. Both mounted on an aluminum pallet. Super simple.
Re: Electric A/C ? [Re: tmef] #2946408
07/23/21 04:42 PM
07/23/21 04:42 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I wonder if one could use a starter motor to drive a rotary compressor for a cheap equivalent?
Re: Electric A/C ? [Re: Sniper] #2947259
07/26/21 10:48 AM
07/26/21 10:48 AM
Manitoba, Canada
Manitoba, Canada
A starter isn't made to do that sort of duty cycle. I think it would overheat and/or eat brushes.
Re: Electric A/C ? [Re: DaytonaTurbo] #2947274
07/26/21 11:28 AM
07/26/21 11:28 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Substantially less load though. Might be an interesting experiment, if I had a spare compressor and starter to us.
