Turn signals don't work #294552
04/20/09 11:08 PM
04/20/09 11:08 PM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
The turn signals on my '73 Duster stopped working. The tail light bulbs are good so that is not the problem. I have tail lights and brake lights. Can anyone tell me where the flasher is located? I'd like to replace it and see if that does the trick.
Thanks,
Raul
Re: Turn signals don't work [Re: Aspen7695] #294553
04/20/09 11:18 PM
04/20/09 11:18 PM
MNobody Offline
MNobody  Offline
my dart us up under the dash near the ash tray, not sure on a duster but shouldn't be hard to find.
Re: Turn signals don't work [Re: Aspen7695] #294554
04/21/09 12:04 AM
04/21/09 12:04 AM
check turn signal fuse & When you find the flasher jump across the 2 teminals in it's connector(w ign sw on) & move turn signal stalk up/down
Re: Turn signals don't work [Re: RapidRobert] #294555
04/21/09 07:42 AM
04/21/09 07:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just remember there are 2 flashers.One for TS one for 4 ways.Rocky
Chrysler Firepower
Re: Turn signals don't work [Re: therocks] #294556
04/25/09 06:18 PM
04/25/09 06:18 PM
Gilbert, AZ
Gilbert, AZ
Thanks for the replies. I checked the fuses and all are good. I tried the turn signals again. They do flash but it takes about 4-5 seconds between flashes. It is the same for both sides. Does this indicate the flasher is bad?
Raul
Re: Turn signals don't work [Re: Aspen7695] #294557
04/25/09 06:59 PM
04/25/09 06:59 PM
most likely
Re: Turn signals don't work [Re: RapidRobert] #294558
04/25/09 09:25 PM
04/25/09 09:25 PM
Plano, Texas
Dallasdart Offline
Dallasdart  Offline
Plano, Texas
On my dart the flasher is up under the dash and it's looks like a pie (best way I can explain it). It's on a plug by its self. Had the same problem and thought it was the flasher but it was the turn signal switch. Remove the steering wheel and it's in there. Kind of a PITA to replace though.
72 Dart Swinger 360 Project
Re: Turn signals don't work [Re: RapidRobert] #294559
04/25/09 11:01 PM
04/25/09 11:01 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
most likely
It's cheap and easy to replace if that is the problem.
As mentioned, it could be a worn turn signal switch (TSS), too.
Re: Turn signals don't work [Re: In_The_Pink] #294560
04/25/09 11:57 PM
04/25/09 11:57 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
If a new flasher doesn't help, it may be a short to ground in the flasher circuit. Even a minor short takes voltage away from the flasher, which causes it to warm up more slowly, and results in slow flashes. Just my 2 cents.
Re: Turn signals don't work [Re: polkat] #294561
04/26/09 07:05 PM
04/26/09 07:05 PM
Gilbert, AZ
Gilbert, AZ
Thanks guys. I replaced the flasher and it works fine now.
Raul
