Re: Mopar daily driver prices?
[Re: formula_s]
#2945122
07/20/21 11:28 AM
07/20/21 11:28 AM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
My brother daily drives a 69 Buick GS400/4 speed every day. Work trip is 20+ miles each way. He added A/C for comfort (he's in Phoenix).
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: tboomer]
#2945129
07/20/21 11:47 AM
07/20/21 11:47 AM
Posts: 31,034 Oregon
AndyF
I can drive my Coronet on a daily basis around town but I wouldn't take it longer drives out of town, especially with the family on board. The Coronet has been updated with power steering, EFI, four wheel disc brakes, big anti-sway bar, Koni shocks and 17 inch radial tires so it starts, stops, handles and gets decent gas mileage. But it doesn't have cruise control, back up camera, AC, climate control, air bags, shoulder belts, etc. so you give up some safety and comfort when compared to a modern car. I don't think I'd sell my Coronet for less than $30K so it wouldn't be a "cheap" daily driver Mopar. Good luck finding an updated daily driver muscle car Mopar for much less than $30K. Anything less expensive than that will most likely be a "classic" with bias ply tires, worn out suspension, drum brakes, worn out engine, etc.
[Re: a12rag]
#2945133
07/20/21 11:54 AM
07/20/21 11:54 AM
AndyF
think you might be better off with like 2006 and up models . . . I have an 06 Magnum RT AWD, had since new, and been great daily driver . . . of course up here in great white north, having AWD is awesome in winter time ! Great combo, 5.7 hemi and AWD !! . . . of course these are up in value now, thanks to pandemic . . . depends on how much $$ you want to spend and then spend on maintenance for reliability . . Or a truck. I have a super clean 2004 Dodge Ram truck with 140,000 miles on it that is a great daily driver. I'd jump in it and drive cross country if I had to and it is almost 20 years old.
[Re: tboomer]
#2945203
07/20/21 02:29 PM
07/20/21 02:29 PM
Posts: 12,799 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
I used my 68 Charger as a DD for about 3 years and it was great. PS/PB/AT made all the difference. I have a 71 RR with manual everything and it's....not great as a DD.
Trying to enjoy life!
[Re: calmopar]
#2945228
07/20/21 03:19 PM
07/20/21 03:19 PM
AndyF
I used my 68 Charger as a DD for about 3 years and it was great. PS/PB/AT made all the difference. I have a 71 RR with manual everything and it's....not great as a DD. Yeah I agree. My '65 Coronet is manual transmission and I got caught in some stop and go traffic on the freeway once coming home from a short trip. That was not fun, especially on a long up hill stretch of the freeway where I was constantly slipping the clutch as the traffic slowly inched forward. An automatic trans would've made that drive 10x easier. I now avoid traffic when driving that car.
[Re: AndyF]
#2945237
07/20/21 03:50 PM
07/20/21 03:50 PM
Posts: 11,374 NJ
rdrnr6970
Your #1 source for current events
NJ
Years ago you could buy a cheap DD type mopar.700.00 2 DR Coronet as well as others..I used to drive my car to work and back home.Friends would help each other out to fix things,or if someone needed something.The cars these days even basic mopars are to expensive for me.
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
[Re: Neil]
#2945256
07/20/21 04:34 PM
07/20/21 04:34 PM
AndyF
You can drive old stuff in town here just fine. The place I'd stay away from is the freeway as most old cars with 3 speed transmissions don't fit in with the current 85 mph or more speeds. Yeah cruising at 75+ can be a little rough on the old stuff. My '65 Coronet has 3.23 gears and a 5 speed manual so freeway speeds aren't a problem but I hate running into traffic jams on the freeway in that car. I suppose if I want to make it a daily driver I could go G3 Hemi with an 8 speed transmission. Actually I think I'm going to convert my '65 Coronet to electric if I keep it. If I put a Tesla drivetrain under it then it would be a great daily driver. Might cost a bunch to do the conversion but it would make the car easy to drive.
[Re: AndyF]
#2945265
07/20/21 04:57 PM
07/20/21 04:57 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
You can drive old stuff in town here just fine. The place I'd stay away from is the freeway as most old cars with 3 speed transmissions don't fit in with the current 85 mph or more speeds. Yeah cruising at 75+ can be a little rough on the old stuff. My '65 Coronet has 3.23 gears and a 5 speed manual so freeway speeds aren't a problem but I hate running into traffic jams on the freeway in that car. I suppose if I want to make it a daily driver I could go G3 Hemi with an 8 speed transmission. Actually I think I'm going to convert my '65 Coronet to electric if I keep it. If I put a Tesla drivetrain under it then it would be a great daily driver. Might cost a bunch to do the conversion but it would make the car easy to drive. I agree with this. On my LRE I turn around 3,000 rpm at 70 mph with 3.55s and to add I have a 3 inch exhaust with headers exiting the factory location.
