No Start Issue
#2944991
07/19/21 10:43 PM
07/19/21 10:43 PM
Posts: 116 Eastern Shore of Maryland
nasty68
Long story short, i was changing the converter in the car and i used my button connected to the relay to bump the motor over to take out the converter bolts. Pull trans, swap converter and put everything back together. Hit the button i had connected to the relay and the motor spun about a eight of a turn and that was it. I have not been able to get the motor to crank yet. I put a breaker bar on the on crank to finish getting the converter bolts in so the motor will spin. One thing i notice is the car will have power but if i try to start the car, it loses all power. None of the lights will come on or the dome light. If it sits for a minute, the lights will start to work again. I am not great with electrical. I tried checking all the grounds in the car, cleaned all the connections on the relay and the bulk head connector in the fire wall. Pulled the headlight switch to check the terminals. I need some advice. I have to be missing something.
68 dart, 383, 727 2013 Jeep JKU Sahara
Re: No Start Issue
[Re: nasty68]
#2944996
07/19/21 11:30 PM
07/19/21 11:30 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I would start by checking the connections on the back of the ammeter gauge. All of the power goes through there except, of course, for the power that goes directly to the starter. Put the power to the ignition switch and the dome light and everything else does. Sometimes they're not loosen up on the studs on the back of the gauge and cause problems similar to what you are having.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: No Start Issue
[Re: Hemi_Joel]
#2944999
07/19/21 11:32 PM
07/19/21 11:32 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
I would start by checking the connections on the back of the ammeter gauge. All of the power goes through there except, of course, for the power that goes directly to the starter. Put the power to the ignition switch and the dome light and everything else does. Sometimes they're not loosen up on the studs on the back of the gauge and cause problems similar to what you are having. Not likely the cause IF using a pushbutton on the relay...
Re: No Start Issue
[Re: Jim_Lusk]
#2945008
07/19/21 11:48 PM
07/19/21 11:48 PM
Hemi_Joel
Minnesota
I would start by checking the connections on the back of the ammeter gauge. All of the power goes through there except, of course, for the power that goes directly to the starter. Put the power to the ignition switch and the dome light and everything else does. Sometimes they're not loosen up on the studs on the back of the gauge and cause problems similar to what you are having. Not likely the cause IF using a pushbutton on the relay... Good point. If he's using the remote button, and it is connected directly to the battery. If that is the case, then I agree that the battery cables and battery cable connections are the best place to start.
Re: No Start Issue
[Re: Andrewh]
#2945046
07/20/21 07:11 AM
07/20/21 07:11 AM
nasty68
Battery is in the trunk, thru the main disconnect at the bumper and from there to the starter. Battery is sitting at 12.6 volts. I keep the car on a trickle charger when not driving. As far as the bumps on the starter, it was enough to undo all 4 converter bolts and then get one in and it wouldn't bump to the next bolt. Ammeter has been by passed. I messed with it some last night and if i try to bump the motor over nothing happens. Once i try that i check voltage and it is at 7 volts. If i let it sit for a minute it will come back to 12.6 volts. I will pull the starter back off and redo the connections from the battery cable and the cable that runs to the relay. It almost seems to me it has to be somewhere in that area being it won't crank with a button or jumping the terminals at the relay.
Re: No Start Issue
[Re: Andrewh]
#2945145
07/20/21 12:09 PM
07/20/21 12:09 PM
nasty68
if you are measuring at the battery and it reads 7, your battery is toast. 12.6 is a little low anyway, I would expect something like 13 for a fully charged battery, but meters may vary. That 7 is only after i hit the key or try to turn the motor over.
Re: No Start Issue
[Re: Sniper]
#2945379
07/20/21 09:02 PM
07/20/21 09:02 PM
nasty68
Just to be clear, it doesn't have 7 volts while cranking. It never cranks. It doesn't even make a noise, not even a click. After i try to start by the key or the push button I can let off of everything and the car is reading 7 volts. I can open the door and the dome light is dim, i turn on the headlights and they barely come on. I can turn the headlights off and shut the door, then turn on the lights and open the door and everything is back to normal. I have the battery on charge and i may pull the one out of my jeep and try that one to see what happens. It's not even a year old. Everything was fine until i pulled the transmission. I will concentrate on the battery, cables and connections tomorrow and see what happens.
Re: No Start Issue
[Re: nasty68]
#2945512
07/21/21 10:34 AM
07/21/21 10:34 AM
nasty68
It looks like it may be the battery. May be a crude way to check but i took jumper cables and attached them directly to the battery and then to the starter and tried to jump the terminals and nothing. Took it over to the truck and did the same thing and the starter took right off. I never thought it would have been the battery as the car was just running and had been starting fine. I really appreciate the help you guys have given. Thanks.
Re: No Start Issue
[Re: nasty68]
#2945515
07/21/21 10:39 AM
07/21/21 10:39 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I agree sounds like battery Its not a no start.Its a no carnk.Cant believe people still call no crank as no start.Drove me nuts when I was working.Rocky
Chrysler Firepower
Re: No Start Issue
[Re: buildanother]
#2945619
07/21/21 01:43 PM
07/21/21 01:43 PM
Posts: 19,629 north of coder
moparx
First thing to do is give each cable clamp a good twist with channelocks at batt posts. Sounds llike a crappy bite on posts. please don't take this as me picking on you, but that is a good way to break the posts away from the internal plates, as well as possibility of cracking the case in the area the posts protrude from it. the connections don't need to be tightened to the specs of a head bolt. it's best to remove the cable and clean both the post and the cable end good, then re-install. tighten snug until you can't move the cable end by hand, then a tick more. a spray of wd-40 now and then prevents the green "stuff" from growing in and around the connection. just my experience and opinion from 55+ years of playing with cars. your mileage will vary. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
