Spark plug help #2944857
07/19/21 02:29 PM
07/19/21 02:29 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
I have a 400 to 526 wedge stroker and was looking for a spark plug recommendation. I’m running Indy ez cnc 295 heads. 11.1 comp with a 275 at 50 duration hydraulic roller cam and a 1050 dominator thumper carb. Also has msd 6al ignition. Street car pump gas.
Thanks in advance
Brandon
Re: Spark plug help [Re: Canam800] #2944871
07/19/21 03:19 PM
07/19/21 03:19 PM
AndyF Offline
AndyF  Offline
Probably a NGK 7 heat range. I typically use a 6 on the street but your compression is a little higher so I'd go one step colder.
Re: Spark plug help [Re: AndyF] #2944877
07/19/21 03:40 PM
07/19/21 03:40 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
What plug # would I order then?
Brandon
Re: Spark plug help [Re: Canam800] #2944879
07/19/21 03:51 PM
07/19/21 03:51 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Autolite AR3934 hands down...I love those plugs. AR3935 are hot, and AR3933 are cold...34's are right in the middle....
Re: Spark plug help [Re: AndyF] #2944885
07/19/21 04:16 PM
07/19/21 04:16 PM
an8sec70cuda Offline
iagree NGK 4091
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spark plug help [Re: Canam800] #2945028
07/20/21 01:19 AM
07/20/21 01:19 AM
Autolite # 3922 or the little hotter 3923 for pump gas with your compression ratioscope up
Colder is better to test with first and go from there twocents
Both of those plugs are street legal resistor plugs, not the illegal on the street non resistor race plugs twocents work
I like and use Champion brand, RC9YC should work fine also up
Re: Spark plug help [Re: Cab_Burge] #2945196
07/20/21 02:11 PM
07/20/21 02:11 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
Thanks. Ordered up some NGK to try.
