79' B300 Van Suspension Lift
#2944243
07/17/21 11:37 AM
07/17/21 11:37 AM
Posts: 345 Chino Valley
B300 VanDanage
Chino Valley
Greatings! First time here in the offroad section... My vehicle: 79' B300 Extended Cargo Van with rear 'Loadlifter 5000' airbags AND a set of 'Hellwig' helper springs on the original 16.5" wheels. Yes I have both helper springs and bags and it feels like a wagon but that's not why I'm here. I live rural and need better tires, traction and clearance so after finding out the original rim size has 0 options for tires I decided to buy a set of 17" wheels. I've decided I want 285 70r17's all the way around and the airbags provide enough of a lift to get them under the rear but there is no chance I'll be able to fit the same size tire in the front without a significant lift. I've been searching on the Net and I can't find any kits or lift parts for my vehicle suspension other than the airbags I already have and some 1 1/2" coil spacer for the front which I'm not even sure are correct... This is not a performance vehicle and I don't want to spend much money to get it lifted so with that criteria can anyone help me find a lift for the front suspension of my van on the cheap? ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Is there a compatible part off another vehicle I can swap to give me the ground clearance I need? I figure some bigger springs or a spring spacer/extension would do it... I don't mean those cheap spacers that you sandwich into the spring, I mean a bolt in tower extension... Any help figuring out getting the lift for my front suspension would be greatly appreciated! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: 79' B300 Van Suspension Lift
[Re: B300 VanDanage]
#2944269
07/17/21 12:31 PM
07/17/21 12:31 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
A lot of folks use a van lower control arm on the d series trucks to drop them 1". Maybe putting a dseries lcr on your van would raise it the same? That combined with some new coil springs in the front might gain you an inch and half or two inches of additional clearance.
[Re: mgoblue9798]
#2944451
07/18/21 12:47 AM
07/18/21 12:47 AM
B300 VanDanage
Chino Valley
A lot of folks use a van lower control arm on the d series trucks to drop them 1". Maybe putting a dseries lcr on your van would raise it the same? That combined with some new coil springs in the front might gain you an inch and half or two inches of additional clearance. I'll need at least 3" for the tires I'll be running but every little bit helps... I haven't looked into D series trucks but I recon there may be some suspension components that are interchangeable... How am I suppose to find out what will fit my B300? How do I find what vehicles have interchangeable parts with my van? It's a 1 ton van so would any similar year 1 ton Dodge truck part be interchangeable?
#2944461
07/18/21 06:10 AM
07/18/21 06:10 AM
Posts: 5,953 ohio
ruderunner
ohio
Reversing the pickup lowering plan might work. Search for info on lowering a pickup and then use the truck arms on your van.
You need to confirm if you have the heavy duty front end or light duty. Look at the tie rods, if inner and outer look the same, it's light. If the inner is much longer than the outer, it's heavy.
Angry white pureblood male
#2944511
07/18/21 10:52 AM
07/18/21 10:52 AM
mgoblue9798
Atlanta, GA
A lot of folks use a van lower control arm on the d series trucks to drop them 1". Maybe putting a dseries lcr on your van would raise it the same? That combined with some new coil springs in the front might gain you an inch and half or two inches of additional clearance. I'll need at least 3" for the tires I'll be running but every little bit helps... I haven't looked into D series trucks but I recon there may be some suspension components that are interchangeable... How am I suppose to find out what will fit my B300? How do I find what vehicles have interchangeable parts with my van? It's a 1 ton van so would any similar year 1 ton Dodge truck part be interchangeable? Sorry I don't know any more than what I shared. You could consider running a shorter tire in the front. Might check into some taller coil springs as well.
[Re: mgoblue9798]
#2944674
07/18/21 09:10 PM
07/18/21 09:10 PM
Posts: 10,642 Freeport IL USA
poorboy
Freeport IL USA
I had an 80 B300 with the heavy duty front suspension. It also had the 16.5 wheels. I ran the 9:00 16.5 tires on my van, and those would rub on about everything when you turned the wheels sharp. My tires rubbed against the frame behind the tires, and the front inner structure at the inside of the front end. They were also very close to the front bumper corners, and on bumps would make contact with the outer sheet metal in the rear fender dog legs. Taller tires will likely reduce the amount you will be able to turn the front tires.
I don't know how the height of what you want to run equates to the 900 16.5 tires, but anything taller or wider is not going to clear the outer or inner fenders and frame, and a taller tire probably isn't going to clear the floor pan, when you turn the wheels to the right or the left.
If you need the amount of lift you are talking to fit the tires under the front end, it probably won't turn very much once you get them under it. You will take a huge hit on the already long turn radius the B vans have to begin with.
I did run dirt track cars before. You can probably hack out anything that interfered with the tire movement to get the clearance you desire, then build back in the structure you need to make the van functionable again.. At some point, any tire will fit anywhere. How bad do you want those tires?
Dodge made the B vans in a 4x4 configuration during the time period of your van. The 4x4 versions were much higher off the ground then the rear drive vans were, maybe that could be a direction you want to look. You only need to mount the front axle and connect the steering, the rest of the 4x4 stuff wouldn't be required. Gene
[Re: ruderunner]
#2944797
07/19/21 11:54 AM
07/19/21 11:54 AM
B300 VanDanage
Chino Valley
You need to confirm if you have the heavy duty front end or light duty. Look at the tie rods, if inner and outer look the same, it's light. If the inner is much longer than the outer, it's heavy. It's a light duty...
[Re: poorboy]
#2944807
07/19/21 12:21 PM
07/19/21 12:21 PM
B300 VanDanage
Chino Valley
Dodge made the B vans in a 4x4 configuration during the time period of your van. The 4x4 versions were much higher off the ground then the rear drive vans were, maybe that could be a direction you want to look. You only need to mount the front axle and connect the steering, the rest of the 4x4 stuff wouldn't be required. Gene I have 235 70's in the front now and plenty of clearance, I'm sure a set of 31.50's would fit as it sits with no issues. I still need to raise the front to level the height. I need at least 2" but I'm shooting for 3...
![Name: 20210719_090320_(1).jpg
ID: 432580 20210719_090320_(1).jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/432580/filename/20210719_090320_(1).jpg)
[Re: NITROUSN]
#2944814
07/19/21 12:40 PM
07/19/21 12:40 PM
B300 VanDanage
Chino Valley
I don't want to spend much money to get it lifted That pretty much is your answer. Its not going to happen without radical modifications and parts. Not cheap. By the time you are done you could of found a 4x4 van cheaper. I know, any tire will fit anywhere if you make it and I'm definitely not going that route... Maybe shootin for 33's infront is wishful thinking... t's lookin like a 3" lift and 31 10.50's are going to be the way to go... I found 2 1/2" spring inserts and a set of heavy duty springs... After hours of searching these were the only OTC mods I could find for the front end of my van.
[Re: mgoblue9798]
#2944816
07/19/21 12:46 PM
07/19/21 12:46 PM
B300 VanDanage
Chino Valley
A lot of folks use a van lower control arm on the d series trucks to drop them 1". Maybe putting a dseries lcr on your van would raise it the same? That combined with some new coil springs in the front might gain you an inch and half or two inches of additional clearance. I'll need at least 3" for the tires I'll be running but every little bit helps... I haven't looked into D series trucks but I recon there may be some suspension components that are interchangeable... How am I suppose to find out what will fit my B300? How do I find what vehicles have interchangeable parts with my van? It's a 1 ton van so would any similar year 1 ton Dodge truck part be interchangeable? Sorry I don't know any more than what I shared. You could consider running a shorter tire in the front. Might check into some taller coil springs as well. It's definitely a step in the right direction... I appreciate it!
#2944830
07/19/21 01:15 PM
07/19/21 01:15 PM
B300 VanDanage
Chino Valley
So this is what I've been able to find on the net... Maybe this will work? These parts and the control arms of a truck I think may just give me the desired lift but I'll probably have to go with 31's instead of 33's... Ok now other than placing parts side by side to see if they match how can I find a compatible vehicle? Is there a manual listing all interchangable parts for dodge 1 tons? I'm kinda hoping someone can just tell me what model truck has the exact same parts my van does, it would help a lot!
[Re: NITROUSN]
#2944868
07/19/21 03:00 PM
07/19/21 03:00 PM
B300 VanDanage
Chino Valley
Another thing you will find out when raising the front. You most likely will not be able to align it. How so? It's not much of a difference with spacers and HD coils...mayne truck arms but we'll see... For now it's just going to be spacers and coils...
[Re: NITROUSN]
#2944873
07/19/21 03:23 PM
07/19/21 03:23 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
When you raise it the tops of the tires pull inwards. You most likely can not get the camber and caster back in specs. Other way around, raising a car creates positive camber (tops of tire goes OUT).
#2944925
07/19/21 07:17 PM
07/19/21 07:17 PM
Posts: 5,953 ohio
ruderunner
ohio
So this is what I've been able to find on the net... Maybe this will work? These parts and the control arms of a truck I think may just give me the desired lift but I'll probably have to go with 31's instead of 33's... Ok now other than placing parts side by side to see if they match how can I find a compatible vehicle? Is there a manual listing all interchangable parts for dodge 1 tons? I'm kinda hoping someone can just tell me what model truck has the exact same parts my van does, it would help a lot! If you have the light duty front end, forget looking at 1 ton trucks. You have a 3/4 ton front end, basically a half ton front with bigger brakes. When looking for parts, you need stuff for NOT 4000 pound axle. Real 1 ton stuff is a whole different thing, other than the idler arms and drag link, I don't think anything else interchanges. Not even shocks.
