5-Point Seat Belt Install #2944238
07/17/21 11:25 AM
07/17/21 11:25 AM
HR3128 Offline OP
HR3128  Offline OP
I'm working on a slow stocker / bracket-race car & would like to use 3", 5-point type seat belts. Something better than the factory belts.
My question is where to attach the shoulder belts when the car dosen't have a a roll bar & is using OEM seats.
Anyone have any examples of this type install?
Thanks.
Re: 5-Point Seat Belt Install [Re: HR3128] #2944258
07/17/21 12:13 PM
07/17/21 12:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Well...they should be attached close behind the driver, from level with the top of the shoulders to 4" below that, according to the rule book.
The only place you have is the floor - if you find a set long enough. And that is not a good place. It could actually do more harm than good in certain situations. I think I would do without before I went to the floor.
I would ask some slow stocker guys what they are doing. Not a lot of options.
Re: 5-Point Seat Belt Install [Re: CMcAllister] #2944291
07/17/21 02:01 PM
07/17/21 02:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Remember, shoulder belts stop your upper torso from going forward only, the seat belts stop you from going forward and up. So I would set them angling back or to the back seat belt holes. Pretty much in same line as with a cross bar behind seat.
Re: 5-Point Seat Belt Install [Re: cudaman1969] #2944300
07/17/21 02:33 PM
07/17/21 02:33 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
There’s no good way to do this, other than installing a bar-loop in just behind the seat. If you’re going to do that, might as well put a bar in. Any existing point in the car that you pick is going to be just as much or more of a hazard than a safety improvement. Just use the lap & anti-submarine belts until the car has a bar.
Re: 5-Point Seat Belt Install [Re: HR3128] #2944310
07/17/21 03:08 PM
07/17/21 03:08 PM
AndyF Offline
AndyF  Offline
Might be able to make a reinforced area in the package tray behind the rear seat. That would give you an attachment point that is only slightly below your shoulders. There should be instructions in the box on how to mount the shoulder belts. The mounting is important since you can injure yourself if they are mounted wrong. Mounting them to the floor is not correct so don't do that.
Re: 5-Point Seat Belt Install [Re: AndyF] #2944314
07/17/21 03:16 PM
07/17/21 03:16 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Either a cross-brace or a rollbar seem the best options here.
Belts that go far back will likely have some stretch if put to the test.
Another dynamic is side/side torso movement from an impact.
Just how slow - or fast - is the car ? 1/4 or 1/8 mile ?
Re: 5-Point Seat Belt Install [Re: HR3128] #2944315
07/17/21 03:37 PM
07/17/21 03:37 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
I have a 66 Coronet 500 which we just started taking to the track, it’s more of a street car. Before I took it out I ask the tech guy about seat belts and when I told him it would probably run in the 12s he said the stock seat belt would be fine. The first time I took it out it was in the mid 11s and I didn’t feel comfortable with the 50 year old lap belts. I ended up ordering 3 inch 5 point Simpson belts and as per their instructions the shoulder belts use the rear seat belt mounting points behind the driver and come out between the upper and lower seats. I thought mounting them that way would make the shoulder harness too low and too much of an angle, but it seems pretty good and is way better than just the stock lap belt.
Re: 5-Point Seat Belt Install [Re: angleiron2] #2944318
07/17/21 03:51 PM
07/17/21 03:51 PM
I would have a NHRA legal roll boar installed now and install the drivers harness correctly twocents
This is based on the car going faster now than you expected and you and I both know it will go faster as you get better driving it and tuning it, 11.49 is when the roll bar is required, do it now twocents work
Re: 5-Point Seat Belt Install [Re: Cab_Burge] #2944327
07/17/21 04:14 PM
07/17/21 04:14 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
Thanks Cab, but we have a faster car to tweak on ,this one will remain a street car pretty much and a roll bar has its own problems in a car that’s mostly street driven. If it gets near 11.49 I will slow it down some. The car has a really nice all original black bucket seat console interior.
Re: 5-Point Seat Belt Install [Re: angleiron2] #2944357
07/17/21 05:58 PM
07/17/21 05:58 PM
HR3128 Offline OP
HR3128  Offline OP
The project is a 2003 Neon R/T, 150HP,122CI, 4 cylinder, 5 speed manual. The plan is to run NHRA DF/Stock. NHRA DF/S 1/4 mile index is 15.60. It will never be fast. Maybe mid 80s MPH. A roll bar just got add to the to-do list.
Re: 5-Point Seat Belt Install [Re: HR3128] #2944367
07/17/21 06:54 PM
07/17/21 06:54 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Get a rule book, you’ll find out you don’t need any of that stuff. Lap belt and maybe a helmet
Re: 5-Point Seat Belt Install [Re: HR3128] #2944370
07/17/21 07:01 PM
07/17/21 07:01 PM
AndyF Offline
AndyF  Offline
A roll bar isn't a bad idea even if it isn't required by the rules. Stuff goes wrong all the time, sometimes the guy in the next lane has a problem and he ends up in your lane. Even when it isn't your fault it is nice to have a little extra protection.
Re: 5-Point Seat Belt Install [Re: HR3128] #2944372
07/17/21 07:07 PM
07/17/21 07:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
You're only going 80. But in Stock, you can have guys in the other lane going over 160, on 9" tires, and on the brakes.
Just saying.
A little different than the street class at the local track.
Re: 5-Point Seat Belt Install [Re: cudaman1969] #2944381
07/17/21 07:33 PM
07/17/21 07:33 PM
HR3128 Offline OP
HR3128  Offline OP
Got the rule book, got the helmet. It's just one of those "I'd rather have it & not need it than need it & not have it" things.
Re: 5-Point Seat Belt Install [Re: CMcAllister] #2944402
07/17/21 09:20 PM
07/17/21 09:20 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Just saying.
THIS/\
I asked a chassis guy about putting a crossbar behind the seat in a 14 second car to use 5 point belts. His answer was "Why you want belts in the car that will keep you straight up if you go upside down with no bar?".
Re: 5-Point Seat Belt Install [Re: slantzilla] #2944565
07/18/21 02:13 PM
07/18/21 02:13 PM
moparx Offline
moparx  Offline
and for the life of me, i don't understand why it's ok to use up to 50 year old STOCK, 1 3/4" belts, while upgrading to 3" belts requires REPLACEMENT every TWO years ! mad
beer
Re: 5-Point Seat Belt Install [Re: moparx] #2944586
07/18/21 03:53 PM
07/18/21 03:53 PM
HR3128 Offline OP
HR3128  Offline OP
beer
I found out that the 2 year rule doesn't apply for slower cars.
Re: 5-Point Seat Belt Install [Re: cudaman1969] #2944779
07/19/21 10:11 AM
07/19/21 10:11 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Since we are NOT referring to highly reclined single open wheel seating, it has to be noted, any seat strap has to be restrained at each end to be effective.
Most comments here are focusing on only one end of the shoulder belt, the downside of improper positioning is spine compression, not good.
But what I see overlooked, the other end of the shoulder belt attaches to the hopefully across the hips, lap belt.
When the upper torso in an accident moves forward, and applies tension to shoulder harness, the end attached to the lap belt pulls the belt up into the stomach area. A lap belt across the hips is properly containing the largest bone structure in the body. A lap belt that crosses the lower stomach area is in one of the most vulnerable/softest parts of the human body. The misnamed 5th "submarine belt" in our upright seating sedan cars is what prevents the shoulder harness from pulling up the lap belt into the kidneys,liver, pancreas, bladder, etc. in an accident.
Your gonads are of minor concern here. Positioning well the 5th belt is nearly as important as the shoulder belt mounts.
Re: 5-Point Seat Belt Install [Re: jcc] #2944794
07/19/21 11:31 AM
07/19/21 11:31 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
aftermarket belts need to be changed every 2 years per nhra most all track enforce that , oem belts even from the 60's do not expire (even 60 years old)
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 5-Point Seat Belt Install [Re: 440lebaron] #2944835
07/19/21 01:32 PM
07/19/21 01:32 PM
moparx Offline
moparx  Offline
gary
we buy these belts because they supposedly are SAFER than OEM belts, yet 50-60 year old belts are ok, never mind the possibility of them being "stored" out beside the shed for the last 10 years or so. if they are so good at that age, why even bother to install aftermarket belts that need to conform to xyz specs ? just head out to the local junkyard and grab whatever belts you can find. they will be FINE !
and as to the "slower" cars not needing aftermarket belt replacement every two years, not around here. you put those belts in, they need replaced, period !
unless, of course, you run at an outlaw track where almost anything goes.
the excuse given for the two year replacement rule is "we don't know what condition the belt is in." well open your eyes and look ! frayed stitching or webbing, hacks or cuts, improper mounting ? good cause for rejection. yet dried out, stiff webbing, frayed stitching, rusty hardware factory belts still ok ? yeah, RIGHT ! flame
beer
