Re: 79' B300 Van Suspension Lift [Re: ruderunner] #2944933
07/19/21 08:03 PM
07/19/21 08:03 PM
Chino Valley
B300 VanDanage Offline OP
Chino Valley
Originally Posted by ruderunner
Originally Posted by B300 VanDanage
So this is what I've been able to find on the net...
Maybe this will work? These parts and the control arms of a truck I think may just give me the desired lift but I'll probably have to go with 31's instead of 33's...
Ok now other than placing parts side by side to see if they match how can I find a compatible vehicle?
Is there a manual listing all interchangable parts for dodge 1 tons?
I'm kinda hoping someone can just tell me what model truck has the exact same parts my van does, it would help a lot! grin
If you have the light duty front end, forget looking at 1 ton trucks. You have a 3/4 ton front end, basically a half ton front with bigger brakes. When looking for parts, you need stuff for NOT 4000 pound axle.
Real 1 ton stuff is a whole different thing, other than the idler arms and drag link, I don't think anything else interchanges. Not even shocks.
Huh... Idk why I thought my van was a 1 ton blush... The front axle is rated at 3070lbs and the gvwr is 7000lbs... Definitely not 1ton...
Re: 79' B300 Van Suspension Lift [Re: B300 VanDanage] #2945058
07/20/21 08:28 AM
07/20/21 08:28 AM
RWG75
RWG75
If yet gonna lift it, go the whole 9 yards:
Re: 79' B300 Van Suspension Lift [Re: ] #2945235
07/20/21 03:38 PM
07/20/21 03:38 PM
Chino Valley
Chino Valley
I might do that down the road... It can't be that difficult to convert my van into a 4x4...
What exactly do I need?
I'd need a transfer case, drive axles, mounting brackets new this new that...$$$
Re: 79' B300 Van Suspension Lift [Re: B300 VanDanage] #2982157
11/05/21 07:08 PM
11/05/21 07:08 PM
Chino Valley
Chino Valley
I'm back!!! cool
So I just finished putting the new rims and tires on my van and apparently I didn't have to lift it at all!
The front tires are 265/65/r17 and the rear 285/70/r17.
There is more than enough clearance around ALL of the tires and I couldn't be happier... Well, I could but you know what I mean...
I think one size bigger in either front or back would cause issues but apparently I picked out the perfect size tires! boogie
Re: 79' B300 Van Suspension Lift [Re: B300 VanDanage] #2982161
11/05/21 07:30 PM
11/05/21 07:30 PM
Chino Valley
Chino Valley
Clearance!
Re: 79' B300 Van Suspension Lift [Re: B300 VanDanage] #2982162
11/05/21 07:34 PM
11/05/21 07:34 PM
Chino Valley
Chino Valley
The beast!
