What paint to use for brake calipers #294415
04/20/09 10:27 PM
04/20/09 10:27 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
Wht are you guys using to paint your calipers. I am looking for the original cast look. And how hot do the calipers get???
Re: What paint to use for brake calipers [Re: gygeneral] #294416
04/20/09 10:52 PM
04/20/09 10:52 PM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
I bought some spray bomb stuff from a little store called Canadian Tire... ever hear of it? I can't remember what brand it was, but it was caliper paint.
Good luck eh.
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: What paint to use for brake calipers [Re: Fishmarket] #294417
04/21/09 03:39 PM
04/21/09 03:39 PM
Ont, Canada
Ont, Canada
Yes I checked there but all they have is wild colours. I want a natural cast iron look.
OK , let me ask this way, how hot do calipers get???
Re: What paint to use for brake calipers [Re: gygeneral] #294418
04/21/09 03:49 PM
04/21/09 03:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I have seen some high temp paints at CarQuest. I used one that was supposed to be an aluminium color on my Durango. I didn't end up liking the color, so I changed to a "cast" color. They do have a "cast" finish at CarQuest too. I think it is a Krylon brand.
I have had good luck with Eastwoods spraypaints. Alumablast, spraygray and there's another one I can't remember the name of. They aren't high temp paints but I havn't ever had a problem with them flaking. Maybe that's because I always spray clear over every color I use. The clear seems to "seal" out the moisture and accually protect the color coats.
I'm sure people will say that you have to use a high temp caliper paint,but I have seen plenty of high temp paints flake and rust off. I think it is all in the preperation.
Re: What paint to use for brake calipers [Re: burdar] #294419
04/21/09 04:24 PM
04/21/09 04:24 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Engine paint seems to work well too. You should be able to get that in almost any color.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
