whats better 3.23 gears or 3.55? #294308
04/20/09 09:10 PM
04/20/09 09:10 PM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
so whats easier to spin the tires?355 or 323?
is 355 ok for the street?
this is an 8 1/4 axle.
please let me know.thanks
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294309
04/20/09 09:11 PM
04/20/09 09:11 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Not really going to be a noticeable difference in those two. Go with what is cheapest or most conveinent for you to get your hands on.
Might as well put an 8.75 in if you are going to have to spin wrenches.
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294310
04/20/09 09:12 PM
04/20/09 09:12 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
3.55s and yes theyre ok for the street
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294311
04/20/09 09:13 PM
04/20/09 09:13 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I have 3:23 gears and can light up the tires easier than you can say "slick". If you're going to run it at the strip, go 3:55, it could give you a slight edge. For the street and highway, 3:23 is perfect.
Re: whats better 3.23 gears or 3.55? [Re: SomeCarGuy] #294312
04/20/09 09:15 PM
04/20/09 09:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
More gear = more power put down. I've got 3.55's and they are a so-so medium. Highway cruising is pretty much 3000rpm at 65mph and performance is decent. Would be a huge improvement from 2.76's if that's what you have now.
Where's a 16 year old going to get a 8.75 from for an affordable price?
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294313
04/20/09 09:17 PM
04/20/09 09:17 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Either will work. My sig picture is with 3.23's...I now have 3.91's and they are way more fun.
Tire height will also greatly affect gear ratio, a fact that many don't take into consideration.
Re: whats better 3.23 gears or 3.55? [Re: DaytonaTurbo] #294314
04/20/09 09:20 PM
04/20/09 09:20 PM
E
erick72 Offline OP
erick72  Offline OP
E
thats what im saying.the 3.55 geared 8 1/4 suregrip will be fine.
wondering one more thing.
this is an axle out of a 95 dakota.
i just take my 5 lug axles and put them where the dakotas six lug axles are right now right?
it would just be easier instead of switching center gears!
erick
p.s yep i have 2.71 gears.i should have way better aceleration and squeeling right?
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294315
04/20/09 09:30 PM
04/20/09 09:30 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
If thats a 95 Dakota rear, it is NOT an 8 3/4...unless someone put it in. Your B-body axles will not be the correct length for a Dakota rear either.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294316
04/20/09 09:35 PM
04/20/09 09:35 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Houston we have a problem!!!
Re: whats better 3.23 gears or 3.55? [Re: 69L78Nova] #294317
04/20/09 09:38 PM
04/20/09 09:38 PM
E
erick72 Offline OP
erick72  Offline OP
E
its an 8 1/4 under the dakota.
and i measured them out.they are the smae length axle tunes.57 1/2 from drum backing plate to drum backing plate?
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294318
04/20/09 09:42 PM
04/20/09 09:42 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
are the spring perches in the right place on the dakota rear or will you have to reweld them? also i've got a buddy that has a good 904 for you so you won't need to swap driveshafts.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: whats better 3.23 gears or 3.55? [Re: DaytonaTurbo] #294319
04/20/09 10:01 PM
04/20/09 10:01 PM
SomeCarGuy Offline
SomeCarGuy  Offline
There are plenty of deals on parts, you just have to watch. He might have to mow some yard, won't hurt him
What rear is under the car now?
Re: whats better 3.23 gears or 3.55? [Re: SomeCarGuy] #294320
04/20/09 10:06 PM
04/20/09 10:06 PM
E
erick72 Offline OP
erick72  Offline OP
E
8 1/4 the same as the dakota rear end.
same length too.i just wanted to switch axles with my axles in my current 8 1/4.
is that ok?
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294321
04/20/09 10:32 PM
04/20/09 10:32 PM
E
erick72 Offline OP
erick72  Offline OP
E
oh yeah.the axle is from a 94 dakota
im pretty sure all 8 1/4 axles had 27 splines up to 97 right?
i just want to know if i can take my 72 8 1/4 axles and swap them into this new dakota rear end and then bolt the dakota rear end right on in.
is this possible?
sorry for not clearing it up
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294322
04/21/09 12:14 AM
04/21/09 12:14 AM
E
erick72 Offline OP
erick72  Offline OP
E
ok i found out 27 spline was used up to 96 so i think im good as long as my 72 8 1/4 is 27 spline.
anyone know?
Re: whats better 3.23 gears or 3.55? [Re: DaytonaTurbo] #294323
04/21/09 08:37 AM
04/21/09 08:37 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I had (well have) 3.55's and 27" tall tires and while they were fun around town, I HATE HATE HATE HATE HATED them because I do take my car out on the highway/freeway regularly, and my choices were either poking around at 60mph, or go nuts from all the noise and commotion of the engine cranking along at 3000-3300 RPM at 70-75mph. 3.23's will be about a 2-300 RPM drop compared to 3.55's. I kept the 3.55's, but added an A500 (42rh) tranny out of a 90's dakota, which makes my top gear equivalent to a 2.45 rear
if you measure the overall width and spring perch location on your '71-up B body, you'll see that the axle is pretty much identical dimensionally to a C body axle. I'd start looking in junkyards/craigslist for an 8 3/4 or 9 1/4 out of a C body. it should bolt right in. and you might be able to find one set up with a 3.23 pretty cheaply. if you plan on doing a fair amount of highway driving, you might want to try find a 2.94 gear, which to me is the best compromise if you enjoy keeping up with modern traffic on the interstate and not have a headache after an hour
if you're changing out the tranny and since you plan on staying small block, I'd definitely look for a low gear 904 to put in there. they have a 2.74 first and 1.54 second, vs. the standard 2.45/1.45, so a low gear 904 w/3.23's has the same effective first gear ratio as a regular 904/727 with a 3.61 gear. or it makes first gear with your 2.71 rear the same as a standard 904/727 with a 3.03 gear. low gear 904's can be found in just about any 80's M body (5th ave, diplomat, gran fury)
no idea on the B vs. dak rear, they both should be 27 spline (like you said, I think the 29 spline came along in '96-98 range), you'd almost have to take both apart and compare the axle lengths. I have no idea if there was a change to the brake drum sizing or wheel bearings along that time, either. a better way to measure would be from axle shaft (or drum face) flange to flange, not the housing. if one uses 2.5" wide drums and the other uses 3" wide drums, or if the backing plates have different offsets, the axle shafts could be quite different lengths with the housing ends the same distance.
2017 Grand Cherokee Overland
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294324
04/21/09 08:39 AM
04/21/09 08:39 AM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
as long as the length of the axle shafts are the same you should be okay. The 8.25 get a bum rap, because its predecessor was such a bad [Edited by Moparts - Keep it clean] piece of hardware. They are a decent axle, and there is a ton of stuff available for them , both Aftermarket and OEM. if you want to upgrade your brakes look under jeeps. many of them habe a nice disc brake setup that is easily retro fitted to earlier cars.
Re: whats better 3.23 gears or 3.55? [Re: erick72] #294325
04/21/09 10:41 AM
04/21/09 10:41 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I changed from 3:23 to 3:55 and I got happy. engine runs a little bit lighter although higher RPMs, but really allmost unnoticeable.
keeping stocks cams, of course you are moving out the power range, so a next step camshaft will be fine to keep the power range play.
Of course, mileage was affected, but nothing to get lot worried. ( specially doen here in Venezuela, filling a gas tank with US$3 )
Re: whats better 3.23 gears or 3.55? [Re: NachoRT74] #294326
04/21/09 11:02 AM
04/21/09 11:02 AM
P
Paul_Fancsali Offline
P
I ran both 3.55s in a 8.25 and 3.90 in the same so they rev a bit big deal. Most of the engines in the hanger queens could use the rev's to blow out the cob web's. Currently running 4.56s in a 8.75 rear my gas mileage went up 1 mpg gallon to 12 and I drive it 58 miles to track one way using 29.5 tall tires. Point here don't let the RPM issue bother you unless you drive hundreds of miles during the summer, as stated go with taller tire in the back to cut into gear or shorter
Re: whats better 3.23 gears or 3.55? [Re: Paul_Fancsali] #294327
04/21/09 01:55 PM
04/21/09 01:55 PM
WA 98043
thecarfarmer Offline
WA 98043
I guess I must be nuts... I ran a set of 3.91's with E-60/14 tires and a stock 383, and thought it was tolerable on my seventeen-mile-each-way daily commute back in the mid nineties.
That being said, the OP should have enough room in the wheelwells for tall tires to use 'daily' and a shorter set if he wants to take it to the track.
Best of both worlds.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
