Page 45 of 48 1 2 43 44 45 46 47 48
Re: Modern Bullitt build [Re: rhamson] #2942784
07/13/21 08:52 PM
07/13/21 08:52 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by rhamson
Couldn't make it as a prior commitment got in the way. The car looks over the top fantastic. Great job! Maybe I will see it locally in the future around here. Congratulations!
Thanks Ralph! I’m sure we will run across each other at some point!
Pat
Re: Modern Bullitt build [Re: DynoDave] #2942785
07/13/21 08:53 PM
07/13/21 08:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by DynoDave
An amazing car. Looks like it had a great first outing at Carlisle! up
Thank you sir, it was fun but I am glad that it’s over!
Re: Modern Bullitt build [Re: Plum440] #2942786
07/13/21 08:55 PM
07/13/21 08:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by Plum440
Saw her at Carlisle... Amazing!! Your craftsmanship and attention to detail are quite impressive to say the least. I tip my hat to you, Sir.
Thank you for checking it out, big show hard to see at all!
Re: Modern Bullitt build [Re: CDN72SE] #2942787
07/13/21 08:56 PM
07/13/21 08:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by CDN72SE
Excellence from beginning to end, thanks for sharing your restoration with us!!
Thank you for hanging in there all these years;-)
Re: Modern Bullitt build [Re: Neil] #2942789
07/13/21 09:00 PM
07/13/21 09:00 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by Neil
Amazing build! Normally I cringe when people start messing around trying to make a better 68-70 Charger than the factory did, but this one was done right 100%.
Now that the 1st one is done when does mass production start, and where do we leave our deposits? Asking for some friends.
I agree 2nd GEN chargers need no modifications they are timeless just the way they are!
We are excepting cryptocurrency for all future orders;-)
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #2944664
07/18/21 08:53 PM
07/18/21 08:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Put a little over 30 miles on the car this morning. I stopped at a small airport to snap a few pictures by a very cool old hanger. Car ran and performed well! A few small glitches, biggest being the speedometer is not working. I need to troubleshoot if it’s a cable, gear or gauge problem?
Pat
Re: Modern Bullitt build [Re: Keepat] #2944693
07/18/21 10:09 PM
07/18/21 10:09 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Absolutely beautiful Pat. Having finished my build I know what you went through. Your build went beyond and over the top. Master craftsmanship at its ultimate period. Did I say period.
Re: Modern Bullitt build [Re: NITROUSN] #2944932
07/19/21 08:01 PM
07/19/21 08:01 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir! Congrats on finishing your build as well!
Pat
Re: Modern Bullitt build [Re: Keepat] #2945173
07/20/21 12:46 PM
07/20/21 12:46 PM
NJ
rdrnr6970 Online content
Your #1 source for current events
rdrnr6970  Online Content
NJ
Saw youre charger in carlsile pics.Wow!What a car ,looks great!Thanks for sharing the great build of the charger! drive
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: Modern Bullitt build [Re: Keepat] #2945719
07/21/21 05:54 PM
07/21/21 05:54 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Great car, great thread.
If the odometer worked then the speedometer head is inop.
Re: Modern Bullitt build [Re: A990] #2953260
08/12/21 08:32 PM
08/12/21 08:32 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Put the car on the pro-form scales today. It looks like all of the weight savings between the aluminum engine, bumper mounts, 9” rear and RMS coil over suspension shaved off 300 lbs from the factory weight of a hemi 4 speed car. This is amazing considering all of the additional unibody reinforcements I made to the car. My car is 3/4 full of fuel and weighs 3664 lbs. Specs I find online for a factory hemi 4-speed, Dana car comes in at 3974 lbs. That is awesome considering I was shooting for about 200 lbs lighter! The other cool thing is that it’s a bit better than a 45/55 split.
Pat
Re: Modern Bullitt build [Re: Keepat] #2955127
08/18/21 07:21 PM
08/18/21 07:21 PM
Fountaindale
O
OzCharger69 Offline
OzCharger69  Offline
O
Fountaindale
Very nice. Any pics on the antenna motor mounting?
Hard to see in the picture but I had to make a small L bracket to hold the motor
[Linked Image]image post
What can I say, wow wow wow, what a top notch build, I adored every bit of the 45 pages.
I'm just about to install a power antenna on my 69 charger that doesn't even have a fender hole for the antenna. May I ask if this is the antenna you used? Would you remember what fender angle adapter you needed?
https://www.retromanufacturing.com/...omatic-power-antenna?variant=31333675406
I'm thinking of using this one https://www.retromanufacturing.com/collections/antennas/products/fully-automatic-mini-power-antenna
Thanks for any help!
Re: Modern Bullitt build [Re: OzCharger69] #2955235
08/19/21 07:17 AM
08/19/21 07:17 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Order the one in the link I have below it has the correct Mopar looking antenna base. Check with Crutchfield they may have it $40 cheaper than when buying it. Good luck with your building thanks for checking out my project!
Pat
https://www.retromanufacturing.com/products/1968-70-dodge-coronet-fully-automatic-power-antenna
Re: Modern Bullitt build [Re: Keepat] #2956292
08/22/21 01:02 PM
08/22/21 01:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Re: Modern Bullitt build [Re: Keepat] #2956359
08/22/21 03:39 PM
08/22/21 03:39 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
That got me pretty d*mn excited for a thirty second video. Both cars look and sound amazing. Hope you enjoy it for years to come.
Re: Modern Bullitt build [Re: BigBlockGTS] #2956383
08/22/21 05:30 PM
08/22/21 05:30 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
That is the plan!! My daughter-in-law is trying to talk me into building her the green beetle in the movie.
I may have to find a Volkswagen forum to start that build;-)
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #2966626
09/23/21 10:22 AM
09/23/21 10:22 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Picked up the next car a 1966 Pontiac GTO a few weeks ago in Minnesota. Original paint, chrome, interior, engine, trans, and rear! Unmolested 61,000 mile surviver. Car only had 16000 miles in 2002. Amazing documentation from all 3 owners.
No restoration for this car just paint correction cleaning and detailing preservation!
Drove it 1200 mile back home, used/ leaked 1/2 qt of oil. Ran great and made about 13+ mpg.
Pat
Re: Modern Bullitt build [Re: Keepat] #2966790
09/23/21 07:19 PM
09/23/21 07:19 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Had to save this as one of my rotating desktop backgrounds! Congrats on such a successful build. beer
That GTO is sharp! I love Pontiacs too. A lot of the same rebellious spirit in that division as in Ma MOPAR. twocents
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Modern Bullitt build [Re: DynoDave] #2997127
12/20/21 08:09 PM
12/20/21 08:09 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Making progress on the new shop. All the electrical work is complete just waiting for BG&E our local power company to hook up the meter. I was concerned that the slab was a little thin for the two post lift so I opted to cut two 4’x 4’ holes and had two 5’x 5’x 14” slabs poured. Also insulated both of the 12’ x 12’ doors. Cabinets and lift will be here first of the year.
Pat
Re: Modern Bullitt build [Re: Keepat] #2997230
12/21/21 08:26 AM
12/21/21 08:26 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Nice shop Pat!
I like those lights. What are they?
Big Ass fan is a nice addition.
Jackshaft door operators as well!
What is the size? Ceiling looks to be 12-14'?
Exterior shot?
Keep us posted on your next project.
-larry
