383 oil pooling on top of valley pan???? #2942602
07/13/21 11:49 AM
07/13/21 11:49 AM
west palm beach, florida
modelmakerinc Offline OP
Fellas, I got an odd circumstance and cant seem to understand how its possible. The 383 in my Volare (Sold two years back) is having oil "pool" on top of the valley pan. i understand pool as not just seeping but ounces of oil and not burnt or odd in color. it is a stock bottom end with 346 iron heads, an edelbrock RPM intake with the felpro valley pan and thin gaskets. how or where can oil get to the topside of the valley pan, the new owner say the intake was removed and reinstalled and has the same issue.
this seems beyond odd as the oil is splashed up on the bottom side of the pan and i cant think of anyway oil can get on top. any insites are appreciated. Thanks in Advance Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 383 oil pooling on top of valley pan???? [Re: modelmakerinc] #2942607
07/13/21 12:17 PM
07/13/21 12:17 PM
I've seen this before, the oil is splashing, seeping, leaking out of the valley pan on the bottom side of the pan and heads, it is not sealing properly.
I would try thicker gaskets to seal it better.
If that doesn't work you may need to have the intake surfaces corrected to match the angle of the heads.
I've seen many aluminum intakes needing that shruggy
I found that out fighting the same thing but mine was sucking the oil into the intake ports, I remove the pan and cleaned up the heads and intake mating surfaces and set the intake on the heads and used feeler gauges to see how much gap was on all four corners at the top and bottom, it was easily measurable so I wrote them down and took it to a good machine shop and they fixed it by surfacing the intake scope up
Re: 383 oil pooling on top of valley pan???? [Re: modelmakerinc] #2942624
07/13/21 12:46 PM
07/13/21 12:46 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Inspect the valley pan for cracks.
Re: 383 oil pooling on top of valley pan???? [Re: modelmakerinc] #2942626
07/13/21 12:48 PM
07/13/21 12:48 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree Are they sealing the intake bolts also?
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 383 oil pooling on top of valley pan???? [Re: modelmakerinc] #2942633
07/13/21 01:00 PM
07/13/21 01:00 PM
AndyF Offline
AndyF  Offline
That isn't uncommon on high mileage engines. I've seen oil on the valley plate a bunch of times over the years. It either leaks from the oil pressure sending unit, or the distributor, or the intake bolts or a crack in the valley pan itself. Shouldn't take more than a few minutes to figure where it is coming from. Just wipe everything clean and then watch it.
Re: 383 oil pooling on top of valley pan???? [Re: AndyF] #2942637
07/13/21 01:07 PM
07/13/21 01:07 PM
The front is clean and dry, cant be distributor, cant be the oil pressure sending unit, it's not front or rear rails.
I believe its oil wicking up through the threads of the intake bolts. The heads ports are clean and it runs great, does not have vacuum leak.
Too much crankcase pressure maybe or cracked valley pan
Re: 383 oil pooling on top of valley pan???? [Re: modelmakerinc] #2942642
07/13/21 01:20 PM
07/13/21 01:20 PM
Anchorage, Alaska
Anchorage, Alaska
Originally Posted by modelmakerinc
...Too much crankcase pressure maybe or cracked valley pan
Absolutely! It almost looks like the pan is bulged up a little, based on the shape of the puddle of oil towards the middle
440, 4-Speed, 3.54
Re: 383 oil pooling on top of valley pan???? [Re: modelmakerinc] #2942645
07/13/21 01:22 PM
07/13/21 01:22 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Sure looks cracked to me.
Re: 383 oil pooling on top of valley pan???? [Re: TRENDZ] #2942693
07/13/21 04:22 PM
07/13/21 04:22 PM
an8sec70cuda Offline
It can absolutely come through the threads of the intake bolts if they weren't installed w/ thread sealer.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 383 oil pooling on top of valley pan???? [Re: an8sec70cuda] #2942702
07/13/21 05:13 PM
07/13/21 05:13 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
That much oil indicates the valley pan is cracked and blowing oil up through
Re: 383 oil pooling on top of valley pan???? [Re: DoubleD] #2942733
07/13/21 07:10 PM
07/13/21 07:10 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Every time I've ever had that much oil on the Valley Pan it was cracked or rusted out.
Re: 383 oil pooling on top of valley pan???? [Re: an8sec70cuda] #2942741
07/13/21 07:35 PM
07/13/21 07:35 PM
How? confused
Re: 383 oil pooling on top of valley pan???? [Re: Cab_Burge] #2942931
07/14/21 08:17 AM
07/14/21 08:17 AM
How? confused
Crankcase pressure causes it to wick up through the threads. Had it happen to me years ago. Thread sealer on the bolts stopped it.
CHIP
Re: 383 oil pooling on top of valley pan???? [Re: an8sec70cuda] #2943000
07/14/21 11:18 AM
07/14/21 11:18 AM
That had to be a hoop of crankcase pressure shock
I've not seen that as far as I can remember confused
My old 415 HP 1963 M.W. Stocker would blow one or both breather caps off in the burn out with 42,000 miles on the original pistons, the top ring groove had over .011 thousands side clearances puke That was back when NHRA only allowed OEM stock pistons whiney
I should have had those pistons cut wider on the top ring and used a spacer to tighten up those clearances, hind sight is wonderful, isn't it whistling
Re: 383 oil pooling on top of valley pan???? [Re: TRENDZ] #2943066
07/14/21 01:32 PM
07/14/21 01:32 PM
moparx Offline
moparx  Offline
i was thinking the same thing when i saw those pics.
beer
Re: 383 oil pooling on top of valley pan???? [Re: moparx] #2943095
07/14/21 02:19 PM
07/14/21 02:19 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Maybe needs more valve cover venting from the vid I seen of someone beating it a bit. shruggy
STOP POTATO HATE!
Re: 383 oil pooling on top of valley pan???? [Re: Mr PotatoHead] #2944244
07/17/21 11:41 AM
07/17/21 11:41 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Absolutely needs a better crank case ventilation system, and likely a ring job.
So.... what was the verdict in this?
Re: 383 oil pooling on top of valley pan???? [Re: TRENDZ] #2944630
07/18/21 06:52 PM
07/18/21 06:52 PM
I will post when I know more.
