Re: SAVING FRONT END WT.
[Re: A/MP]
#2942631
07/13/21 12:57 PM
07/13/21 12:57 PM
Posts: 4,696 On the parachute mount
n20mstr
it depends on what you removing. Meaning if the new K takes away the T bars and the steering box (rack) then it can be a decent amount 50+ lbs. Now if you changing from stock brakes to aftermarket at the same time, now you going to lose over 100. Most claim 50+ lbs
....BAD A$$ STREET CAR.....
[Re: A/MP]
#2989467
11/26/21 10:46 PM
11/26/21 10:46 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
What year and body style ?
[Re: A/MP]
#2989495
11/27/21 03:10 AM
11/27/21 03:10 AM
Cab_Burge
Are you talking about replacing it with a tubular K member with stock steering and torsion bars or a tubular K member with rack and pinion steering with coil overs in A arms or a strut front end with no K member?
[Re: dOc !]
#2989919
11/28/21 05:36 PM
11/28/21 05:36 PM
Posts: 9,875 MI, usa
dvw
MI, usa
I see claims of 200lb loss. Has anybody ever really weighed the K frame, steering box, linkage, torsion bars, upper arm/ball joint, lower arm/ball joint, spindles, strut rods? Doubt if all these parts weighs 200 lbs total. Shocks and brakes fit either set-up so have no bearing. If you trim the K frame my bet there is very little loss with the exception of going coil over or rack/pinion. Obviously strut, rack/pinion, spindle mount with small brakes is the lightest. But not practical for most applications. Doug
[Re: dvw]
#2989922
11/28/21 05:49 PM
11/28/21 05:49 PM
n20mstr
I see claims of 200lb loss. Has anybody ever really weighed the K frame, steering box, linkage, torsion bars, upper arm/ball joint, lower arm/ball joint, spindles, strut rods? Doubt if all these parts weighs 200 lbs total. Shocks and brakes fit either set-up so have no bearing. If you trim the K frame my bet there is very little loss with the exception of going coil over or rack/pinion. Obviously strut, rack/pinion, spindle mount with small brakes is the lightest. But not practical for most applications. Doug Doug trimming the lip all around on an A body K will usually take 9-10 lbs off . At least on the later 1973 up ones I have done . Heaviest parts on stock front is the Torsion bars , the lower control arms , and don’t forget the Torsion bar mounts in the frame
[Re: dvw]
#2989931
11/28/21 06:33 PM
11/28/21 06:33 PM
Posts: 20,210 Park Forest, IL
slantzilla
Park Forest, IL
I see claims of 200lb loss. Has anybody ever really weighed the K frame, steering box, linkage, torsion bars, upper arm/ball joint, lower arm/ball joint, spindles, strut rods? Doubt if all these parts weighs 200 lbs total. Shocks and brakes fit either set-up so have no bearing. If you trim the K frame my bet there is very little loss with the exception of going coil over or rack/pinion. Obviously strut, rack/pinion, spindle mount with small brakes is the lightest. But not practical for most applications. Doug When I bought my AJE he claimed a loss of 125# on an A body. The fine print was that you were replacing POWER steering and POWER disc brakes. Manual steering and brakes were a lot less of a loss, and a bunch of that came from replacing the factory disc setup with Wilwoods.
[Re: A/MP]
#2989932
11/28/21 06:34 PM
11/28/21 06:34 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Is there any real weight savings in eliminating factory K? A body? If you're wondering about switching to a QA1 K frame - there is no weight savings over a stock one. If you get ALL their parts (like I did) they claim you end up saving a total of 18 lbs but I don't see it. The adjustable aluminum strut bars save the most at a few lbs. each side. The tubular upper A arms are a wash and might even be heavier than the stock ones. Tubular lowers save a little bit of weight but not much, maybe a pound. There's no option to get them without sway bar brackets. On a stock type front end 9 or 10" drum brake-based brakes save the most weight. The spindles are smaller, ball joints are smaller, it's easily 35 lbs. + a side over stock or stock-based parts with street rotors. Race-only brakes would be more. Like said already, switching to a rack/strut style front end is the way to go if you want actual light parts.
'71 Duster '72 Challenger '17 Ram 1500
