Re: Oxygen sensor brand
[Re: 360view]
#2942554
07/13/21 08:42 AM
07/13/21 08:42 AM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
When it comes to sensors for our Mopars you better buy the Mopar brand sensor cause the aftermarket ones won't last a year.
[Re: NITROUSN]
#2942845
07/13/21 11:55 PM
07/13/21 11:55 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
I would scan the computers coolant sensor as it is warming up. It could jump indicating a warm engine so the computer will go lean when you need more fuel. ^^^^ This makes the most sense to me after dealing with "are the O2 sensors my problem" on the wife's T&C and the hungry groundhog. If all is fine after the engine warms up then.................
[Re: NITROUSN]
#2943053
07/14/21 01:05 PM
07/14/21 01:05 PM
Posts: 19,488 north of coder
moparx
I would scan the computers coolant sensor as it is warming up. It could jump indicating a warm engine so the computer will go lean when you need more fuel. i have seen coolant sensors turn green on the bulb that is in the coolant flow. when this happens, it seems the resistance values go wonky, thus scanning in real time could give you a solid clue as to what is going on. if you remove yours and it is tarnished, shine it up with a scotchbrite pad or steel wool and see if that makes it work better. that has worked for me many times, and you really have nothing to loose at this point.
[Re: Cab_Burge]
#2943413
07/15/21 12:11 PM
07/15/21 12:11 PM
moparx
NTK brand O2 sensors are way better than most others, cost more also and to throw "stuff" out there............... my 99 caravan [known as "the bus"] needed a downstream O2 sensor a couple of years back, and of course it was not stocked locally. for some reason, i had two NTK sensors on the shelf, and the box numbers coded out that they were for a ford taurus. i don't know why they were there, but i never through ANYTHING out if it can POSSIBLY be used for something ! anyway, the wires [4-it was a heated sensor] matched the bad sensor on my bus, and were in the same order in the plug. however, the plug wasn't the same as the plug that was on the bad bus sensor. after looking at both sensors for a bit, it became apparent i could swap the plugs, and use the ford sensor on my bus, so why not give it a try ? so i popped the wires out of both plugs and snapped the ford sensor wires in the bus's plug.[in the correct orientation of course] installed the ford sensor and it WORKED ! it's been in the bus now with no problems for several years, works as it should, and no codes set. i couldn't believe it would work, but it has, and i have an extra one [remember, i had two on the shelf] on the shelf if i need it. i guess trying something just because, may be a great learning experience, especially if it works !
[Re: moparx]
#2943956
07/16/21 02:38 PM
07/16/21 02:38 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Installed probally a few hundred at the shop Most weer Bosch They work period In all we used never had a faliure and most cars were abused and driven for years.Rocky
Chrysler Firepower
[Re: therocks]
#2944200
07/17/21 10:17 AM
07/17/21 10:17 AM
Posts: 994 rust belt
Moparite
rust belt
No CEL but needs upstream O2 sensor How do you know that? When it goes into closed loop it idles rough and if I drive it pops through throttle body indicating a lean condition. Not necessarily, You did the plenum but did you use fel pro gaskets? The Hughes ones are junk. When did this issue start? Also what plugs are you running?
