Recommend 833 4 Speed Fluid?? #294209
04/20/09 07:41 PM
04/20/09 07:41 PM
hemibuzz Offline OP
hemibuzz  Offline OP
I know it needs 7 1/2 pints but what have you been using? The car sits an awful lot? Any
ideas?
Re: Recommend 833 4 Speed Fluid?? [Re: hemibuzz] #294210
04/20/09 07:45 PM
04/20/09 07:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
90 W gearoil "."
Re: Recommend 833 4 Speed Fluid?? [Re: DAYCLONA] #294211
04/20/09 08:56 PM
04/20/09 08:56 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Pennzoil synchromesh
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Recommend 833 4 Speed Fluid?? [Re: hemibuzz] #294212
04/20/09 09:32 PM
04/20/09 09:32 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
ideas?
Jamie Passon has his own blend
Re: Recommend 833 4 Speed Fluid?? [Re: torkrules] #294213
04/20/09 10:59 PM
04/20/09 10:59 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
ATF for 73 and later 833 and od833s.
I am truckless..
Re: Recommend 833 4 Speed Fluid?? [Re: 340SHORTY] #294214
04/21/09 07:45 AM
04/21/09 07:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65 oe 4 speed nothing but 90 wt gear oil.Still like new.Rocky
Chrysler Firepower
Re: Recommend 833 4 Speed Fluid?? [Re: 69L78Nova] #294215
04/21/09 07:56 AM
04/21/09 07:56 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
This stuff is the best!
Re: Recommend 833 4 Speed Fluid?? [Re: hemibuzz] #294216
04/21/09 08:38 AM
04/21/09 08:38 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Azmopardart and LAR414 have it right. Pennzoil Synchromesh is good stuff. Recently, I drained the 90W gear lube out of my A833 and put in the Synchromesh and it definitely shifts better.
Re: Recommend 833 4 Speed Fluid?? [Re: mrob] #294217
04/21/09 11:31 AM
04/21/09 11:31 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I've been looking for Pennzoil Synchromesh locally and nobody seems to stock it. I have access to BG synchro shift and it's GL4 rated. Anybody ever tried it?
Re: Recommend 833 4 Speed Fluid?? [Re: Silverbullet2] #294218
04/21/09 03:40 PM
04/21/09 03:40 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
AUTO ZONE will have it
Re: Recommend 833 4 Speed Fluid?? [Re: TOMRR] #294219
04/21/09 08:50 PM
04/21/09 08:50 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
There are many favorites out there but the one oil to avoid is any gear oil that is GL5 rated.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Recommend 833 4 Speed Fluid?? [Re: Silverbullet2] #294220
04/21/09 08:52 PM
04/21/09 08:52 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Just go to any GM dealer and get Synchromesh.
MB
Re: Recommend 833 4 Speed Fluid?? [Re: hemibuzz] #294221
04/21/09 10:12 PM
04/21/09 10:12 PM
hemibuzz Offline OP
hemibuzz  Offline OP
Whats wrong with GL-5 Rated 90W???
Re: Recommend 833 4 Speed Fluid?? [Re: hemibuzz] #294222
04/21/09 11:47 PM
04/21/09 11:47 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
High pressure additives can eat the brass syncros. Most gl-5 contain sulphur, not good for brass.
Re: Recommend 833 4 Speed Fluid?? [Re: TOMRR] #294223
04/22/09 07:57 AM
04/22/09 07:57 AM
North Carolina, USA
North Carolina, USA
TOMRR, stopped by the Autozone and they had 4 quarts on the shelf. ( I had checked with advance and napa...) Thanks a million!
Re: Recommend 833 4 Speed Fluid?? [Re: hemibuzz] #294224
04/22/09 10:20 AM
04/22/09 10:20 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Somebody correct me if I am understanding this wrong but the GL-5 has an extreme pressure additive package that works great to eliminate friction on high PSI contact like ring and pinion tooth contact. Problem is it also does the same thing when the the points on the inside of the brass rings try to grip the cone of the gears when shifting. You want that brass to lock onto that taper quick and stop that gear as soon as possible.
Re: Recommend 833 4 Speed Fluid?? [Re: CJK440] #294225
04/22/09 10:38 AM
04/22/09 10:38 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
You are correct sir....
Re: Recommend 833 4 Speed Fluid?? [Re: Cuda340] #294226
04/22/09 11:03 AM
04/22/09 11:03 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I accidently put a GL-5 oil in my trans one time and it wouldnt even go into gear. Put the Pennzoil back in....like butter
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Recommend 833 4 Speed Fluid?? [Re: HPMike] #294227
04/22/09 01:36 PM
04/22/09 01:36 PM
Minnesota
69Y2RT Offline
69Y2RT  Offline
Minnesota
MB
Or Dodge dealer
GM part# 12345349
Dodge part# 4874465 or 4874464
Amsoil# MTF-QTCA
1969 Coronet R/T Y2 Y2 P6X X9 V8X 1967 Satellite 383 4speed
Re: Recommend 833 4 Speed Fluid?? [Re: 69Y2RT] #294228
04/22/09 04:32 PM
04/22/09 04:32 PM
SW Minnesota
Dennis_K Offline
Dennis_K  Offline
SW Minnesota
I asked the same question when the time came to fill my trans in the Charger, and got the same response, so I went to my local Napa and asked for the Pennzoil synchromesh fluid. They didn't have it, but they had the Amsoil stuff and it said on the bottle that it meets all the same specs as the GM and Chrysler fluids, so I gave it a try and I'm very happy with the way it shifts. The only "problem" is that there is so little oil drag on the gears that the clutch disc doesn't stop spinning when I push the pedal, so I got into the habit of shifting into first and then quickly into reverse before backing out of my garage. Shifting directly into reverse resulted in gear clash noise.
