power glide question #2941722
07/10/21 08:48 AM
07/10/21 08:48 AM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
I have a question about the starter did you need a spacer between the starter and the bell housing if so how thick thanks for the help
Re: power glide question [Re: dbran451] #2941746
07/10/21 10:34 AM
07/10/21 10:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Depends on whos parts you are using for the install. But yes I have always had to use one and depending on whos parts between .020" to 3/8"!
Re: power glide question [Re: dbran451] #2941747
07/10/21 10:37 AM
07/10/21 10:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
There is no 'one answer fits all' here unless the answer is "*it depends*". Basically you'll have to determine what distance you'll need depending on the type of starter IN EVERY APPLICATION. There just are so many ways to retrofit a PG, so many different parts available (INCLUDING CONVERTER) you could list everything but still the answer is the same. On my Tilton the free gap was .100" plusminus .040 AND to set the backlash between .01 and .03"
Re: power glide question [Re: Al_Alguire] #2941748
07/10/21 10:38 AM
07/10/21 10:38 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Dammit beat me to the punch again!
Re: power glide question [Re: Al_Alguire] #2941774
07/10/21 12:01 PM
07/10/21 12:01 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
we are using a JW bellhousing with a Meziere flexplate and an ATI converter
Re: power glide question [Re: dbran451] #2941785
07/10/21 12:33 PM
07/10/21 12:33 PM
Call all three of them and see what they want for their parts scope
Re: power glide question [Re: Cab_Burge] #2941807
07/10/21 02:15 PM
07/10/21 02:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Some of the adapters that mount the flywheel to the crank determines a lot. Some go on the engine side and some go towards the transmission
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: power glide question [Re: pittsburghracer] #2941851
07/10/21 04:52 PM
07/10/21 04:52 PM
NC
440Jim Offline
440Jim  Offline
NC
Good points.
Just to show the wide range of results, here is my combo:
PG with JW Ultrabell
ATI flexplate and crank adapter
440 stock block
Power Master mini starter (normal size Denso style mini starter)
1/4" thick midplate between the block and JW bell housing.
Turbo style converter (Ultimate Converter) (PG has turbo input shaft); and 1/4" thick spacers between the converter lugs and flexplate (supplied by Ultimate Converters).
Starter spacer (two pieces) 0.537"
And the starter nose uses the JW nose extension too.
Part of that thickness is because the previous owner cut the midplate opening so 1/4" is just for the midplate thickness.
Re: power glide question [Re: Cab_Burge] #2941859
07/10/21 05:09 PM
07/10/21 05:09 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
what does the cost have to do with the question
Re: power glide question [Re: dbran451] #2941862
07/10/21 05:22 PM
07/10/21 05:22 PM
PA.
"Little"John
"Little"John
PA.
Here’s some of my stash of parts from over the years as I’ve used a lot of different kits in my small and big blocks I got a few of those shim packs from summit and they work great.
04FA98EE-565E-4C64-8C72-3C83EC3FA8A9.jpeg31E6274E-A4F4-44C7-8F63-3B9E46ABE78B.jpeg6FCC7B33-494C-48AA-AEEA-CFA34D358231.jpeg
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: power glide question [Re: pittsburghracer] #2941902
07/10/21 08:18 PM
07/10/21 08:18 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
you wouldn't happen to have the part number for the JW shim package
Re: power glide question [Re: dbran451] #2941915
07/10/21 09:28 PM
07/10/21 09:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Bought mine from Coan set mine up and it all fit.
Re: power glide question [Re: dbran451] #2941921
07/10/21 09:46 PM
07/10/21 09:46 PM
PA.
"Little"John
"Little"John
PA.
[quote][/quote]
I just got out of the hospital and I’m kind of wiped out but I will try to look it up tomorrow
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: power glide question [Re: dbran451] #2941924
07/10/21 09:49 PM
07/10/21 09:49 PM
The question was what space they want on between the converter and their parts, not costs shruggy
I have been told by A1 and Mikes Tranny two different specs. on that space shruggy work
FTI wants theirs different also shruggy
Re: power glide question [Re: dbran451] #2941928
07/10/21 10:04 PM
07/10/21 10:04 PM
NC
440Jim Offline
440Jim  Offline
NC
#92472
Re: power glide question [Re: 440Jim] #2941933
07/10/21 11:02 PM
07/10/21 11:02 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
We used a JW bell with his crank adapter, The Wheel and shim kit to start. Didn't like all the shims so after determining the thickness needed, we made 2 1/4" aluminum spacers. 1/8"mid plate from when we had the 3 speed so it was scalloped to allow the starter to mount against the bell. Standard GM converter with 1/8" shims between the flexplate and converter pads. Mopar Performance starter. Worked perfect..
Re: power glide question [Re: CMcAllister] #2941995
07/11/21 11:01 AM
07/11/21 11:01 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I just use a 3/8 flat washer
Re: power glide question [Re: scottb] #2942020
07/11/21 12:50 PM
07/11/21 12:50 PM
PA
moparacer Offline
moparacer  Offline
PA
I use shims like Pittsburgh posted in his pic that came with my JW bell years ago.
I only use one with my setup.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: power glide question [Re: moparacer] #2942042
07/11/21 02:11 PM
07/11/21 02:11 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
thanks everyone for the answers its been informative i guess i wont know the answer for our setup until i get the converter back from being checked
Re: power glide question [Re: dbran451] #2942048
07/11/21 02:43 PM
07/11/21 02:43 PM
PA.
"Little"John
"Little"John
PA.
Exactly. Get a good flashlight and after you bolt the starter in check your clearance. Push the starter away enough so you have plenty of clearance. Good luck.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
