4-speed help 😭 #2941367
07/08/21 09:13 PM
07/08/21 09:13 PM
junction city oregon
V
viperblue72 Offline OP
V
Just rebuilt my 23 spline 4-speed for the Cuda. The problem is when I move the 1-2 slider the strut keys pop outward. I had to pull the trans due to this as it stuck in 2nd gear. What gives?
Re: 4-speed help 😭 [Re: viperblue72] #2941375
07/08/21 09:34 PM
07/08/21 09:34 PM
Did you reuse both the retaining spring wires inside under those keys on both the front and rear of the keys? If not you should twocents
I stagger them so both of the ends are not aligned under of the slots in the hub also scope
Re: 4-speed help 😭 [Re: Cab_Burge] #2941389
07/08/21 10:18 PM
07/08/21 10:18 PM
V
V
Cab, I did not replace the wires but they seemed ok. I did stagger them also so that the tabs pop into different keys from one another.
All three keys pop outward when I move the slider all the way into 2nd.
Re: 4-speed help 😭 [Re: viperblue72] #2941391
07/08/21 10:26 PM
07/08/21 10:26 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Did you replace any parts of the synchronizer assembly? There a couple different versions. Also the hub has different length shoulders, is it backwards?
Re: 4-speed help 😭 [Re: jwb123] #2941407
07/09/21 12:00 AM
07/09/21 12:00 AM
V
V
I don’t think it is backwards unless it was before. Here is a pic
Re: 4-speed help 😭 [Re: viperblue72] #2941459
07/09/21 09:51 AM
07/09/21 09:51 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you do that with the side cover off that is a normal condition. The shift forks will not let it go that far when the side cover is installed. Now if it still does that with the side cover and shift forks installed we have a problem. twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 4-speed help 😭 [Re: fourgearsavoy] #2941619
07/09/21 06:57 PM
07/09/21 06:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
1-2 and 3-4 are different make sure you got them back right.
Re: 4-speed help 😭 [Re: viperblue72] #2941721
07/10/21 08:48 AM
07/10/21 08:48 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
https://www.musclecardiy.com/transmissions/how-to-rebuild-chrysler-a883-4-speed-transmissions/#:~:text=The%20A833%20is%20a%20side-loaded%20transmission%20with%20all,The%20outboard%20design%20requires%20an%20additional%20mid%20plate.
Quick overhaul hints with pictures, as mentioned the two syncro hubs have different lengths. If you scroll down the pictures it shows the hub differences.
And how is the endplay of the unit? How much movement if any of the input and output shafts in and out? That can cause your trouble as well.
Re: 4-speed help 😭 [Re: jwb123] #2941758
07/10/21 11:03 AM
07/10/21 11:03 AM
moparx Online content
moparx  Online Content
Re: 4-speed help 😭 [Re: moparx] #2941929
07/10/21 10:17 PM
07/10/21 10:17 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Now begins the debate over dextron or gear oil… good article. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 4-speed help 😭 [Re: astjp2] #2942044
07/11/21 02:26 PM
07/11/21 02:26 PM
my one buddy had a chevy pickup years ago that smoked up a storm and used oil like it was fuel. he dumped used ATF and gear oil in that thing, plus whatever used hydraulic oil and motor oil that my brother and i could provide at the time. he ran that thing for years like that !
and these boneheads today think "rolling coal" is something new............ laugh2
beer
Re: 4-speed help 😭 [Re: astjp2] #2942267
07/12/21 09:16 AM
07/12/21 09:16 AM
VA
dragon slayer Offline
VA
What 4gear said. You have the slide over too far and rubbing on the reverse idler. Does not move to the extremes with shift fork. The slider only engages those syncro teeth on the gear and not that deeply. That is why if the gear teeth are rounded the gear is bad and will probably pop out of gear.
