Re: 1978 W200 frame
[Re: nd65]
#2941679
07/09/21 10:08 PM
07/09/21 10:08 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Most likely 75 to 79 would be for sure exactly the same. 80 to 93 will work but there may be minor snags as you get into it. You also should stay with a 3/4 ton frame. However a 1/2 ton can work. 72-74 could also work. For the most part the 72-93 are very similar. Nothing that some drilling and minor fabrication can not fix.
Re: 1978 W200 frame
[Re: nd65]
#2941733
07/10/21 09:39 AM
07/10/21 09:39 AM
RWG75
RWG75
just about everything swaps or can be made to work 72-93. I always thought rad support mount holes was a 2wd / 4wd thing and know they used both locations in the 70s - the rad supports have two sets of holes. Only xfer case specific cross member is the divorced 205 and ya need something stiffer anyway. 2wd vs 4wd is same frame, different mounts riveted up front. 1/2 ton vs 3/4 ton check frame rail height.
Re: 1978 W200 frame
[Re: larrymopar360]
#2941861
07/10/21 05:16 PM
07/10/21 05:16 PM
RWG75
RWG75
I’ll take that pile for $650 - have a use for most of it.
