Re: MP P4876729 CD ignition box - where to find some info?
[Re: Diplomat360]
#2941754
07/10/21 10:56 AM
07/10/21 10:56 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Yep, it's the same box. You also don't want to use the ballast resistor in the coil circuit anymore, you'd want both the black and orange lead from the MSD to go to the coil directly.
[Re: Blusmbl]
#2941966
07/11/21 08:29 AM
07/11/21 08:29 AM
Posts: 1,761 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Yep, it's the same box. You also don't want to use the ballast resistor in the coil circuit anymore, you'd want both the black and orange lead from the MSD to go to the coil directly. OK, good stuff. Yup, got it re: ballast resistor. Although I do have a question regarding the box's power supply. The diagram shows a straight feed from the battery but that just seems awefully...ummm, risky? Should there not be a fuse at least on this, or perhpas a switched power supply?
[Re: Diplomat360]
#2941998
07/11/21 11:13 AM
07/11/21 11:13 AM
Blusmbl
Plymouth, MI
I’ve installed a few and have always gone right to the battery. They recommend not fusing it in the instructions because it is allegedly internally fused but I do know some people that have put a 20 or 30 amp fuse on the positive lead. It only draws about an amp per 1000 rpm but you also will get current spikes, especially on shutdown.
