440 Heads #2939276
07/03/21 11:02 AM
07/03/21 11:02 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning everyone and Happy 4th of July!!
I am currently freshening up a 76 440 with 4006452 Heads. It ran good before I started
cleaning it up, no smoke at all. I have a pair of 72 3462346 heads, is there any benefit
to changing them out?
Thanks,
Re: 440 Heads [Re: jim6346] #2939277
07/03/21 11:16 AM
07/03/21 11:16 AM
The 452 heads have hard seats for unleaded fuel, the 1971 "346" heads don't.
I'm sure there is very little or no flow improvement between those two heads shruggy
Re: 440 Heads [Re: Cab_Burge] #2939459
07/03/21 03:14 PM
07/03/21 03:14 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
iagree Nothing wrong with the 452's.
"This head has minor variations on the 346 casting from 1971, with differences associated with durability details such as hardened valve seats, improved crack resistance, and an enlarged guide boss in the valve seal area. The intake port remained unchanged from the 1971 346 casting. The exhaust port was never significantly changed and remained true to the form introduced back in 1967 on the 915 heads."
Re: 440 Heads [Re: John_Kunkel] #2939511
07/03/21 05:13 PM
07/03/21 05:13 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
The 452 has been my choice for years. They flow as good as most any of the factory heads, plus as stated, they have induction hardened exhaust seats. I have run them on several healthy street engines over the years and have been happy with them.
Re: 440 Heads [Re: jim6346] #2939727
07/04/21 10:01 AM
07/04/21 10:01 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
This is an instance where members good intentions get $$$ for the original poster mighty fast. The "For the same amount of money to refurb your 452s you can gat new aluminum heads" tend to come out. But- I said But...If the guides on your 452s are good, heads have no damage no cracks- good valves good seats I say clean castings, hand lap the valves and seats. Add new seals and maybe new springs. Very affordable if your heads are not junk. A non priority in your case but none the less a fun option would be some mild cleanup and prep with rotary abrasives. (Mild sensible porting but NOT hogging out!)
Keep old mopars alive.
Re: 440 Heads [Re: 2boltmain] #2940595
07/06/21 06:13 PM
07/06/21 06:13 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
452 heads have an induction hardened exhaust seat not much good after the seats have been ground, The 346 head is the same, look on the end of the 346 head for two raised strips, this346 head has the hardened seat.
