Plz Identify Clock Cable #2940419
07/06/21 09:05 AM
07/06/21 09:05 AM
Canada
E
EW1BH27 Offline OP
EW1BH27  Offline OP
E
Canada
When Borg Instruments were around I asked them if they also had the clock cable that went with their Cuda rallye clock (2984182). They sent me what's in the picture and obviously it isn't. It measures about 16 1/8 inches. Can anyone tell me its application or if it's even Mopar. Thanks
Re: Plz Identify Clock Cable [Re: EW1BH27] #2940476
07/06/21 11:29 AM
07/06/21 11:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
What kind of clock runs on a cable? I think you mean Tachometer.
Re: Plz Identify Clock Cable [Re: NITROUSN] #2940481
07/06/21 11:35 AM
07/06/21 11:35 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
They have a cable that runs from the back of the clock to a stem or knurled knob under a “ledge” on the dash for setting the time in the clock. Sorry no idea how to ID them.
Re: Plz Identify Clock Cable [Re: NITROUSN] #2940482
07/06/21 11:38 AM
07/06/21 11:38 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That looks to me like a 68-69 A-body Barracuda clock cable.
I have several just like that that I removed from dashes from those cars.
Second picture is what an e-body clock cable looks like, different in that it uses the reset knob and barrel screw, that screws on to threaded cable end as shown in last picture
Re: Plz Identify Clock Cable [Re: NITROUSN] #2940492
07/06/21 12:28 PM
07/06/21 12:28 PM
Canada
E
EW1BH27 Offline OP
EW1BH27  Offline OP
E
Canada
It doesn't run the clock, it's used to set/reset the time.
Thank you mccannix, I got the correct one from PG Classics back when they became available.
Re: Plz Identify Clock Cable [Re: EW1BH27] #2941019
07/07/21 11:44 PM
07/07/21 11:44 PM
Maryland
MoparMike1974 Offline
Maryland
I think 70 E body rallye dash used the clock cable. In 71 or 72 they changed it so the knob just came through the front of the clock lens. However, it does not look correct for the application. Im sure other cars used them like C body or B bodys.
