Page 1 of 3 1 2 3
Best engine combo for a 9 second Duster! #2938314
06/30/21 11:51 AM
06/30/21 11:51 AM
Isle of Sheeps
Gtxxjon Offline OP
Gtxxjon  Offline OP
Isle of Sheeps
Whats the best engine combo for a 9 second Duster?
Stroker 360.
Stroker 400.
Normal 440.
Stroker 440.
Last but not least a HEMI!
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Best engine combo for a 9 second Duster! [Re: Gtxxjon] #2938316
06/30/21 11:55 AM
06/30/21 11:55 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
cant beat a stroker 440 with some 440-1 heads. SOLID 9 sec combination, even at a "heavy" weight
....BAD A$$ STREET CAR.....
Re: Best engine combo for a 9 second Duster! [Re: n20mstr] #2938318
06/30/21 12:02 PM
06/30/21 12:02 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Stroker 360 with small block Indy heads
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best engine combo for a 9 second Duster! [Re: n20mstr] #2938320
06/30/21 12:05 PM
06/30/21 12:05 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
9's all day....Went a 9.58 over the weekend with mine out the back door on a super humid day..
https://www.youtube.com/watch?v=vKgihckS-5Q
Re: Best engine combo for a 9 second Duster! [Re: Gtxxjon] #2938321
06/30/21 12:23 PM
06/30/21 12:23 PM
Stroker 400 that has been sonic tested before building, bore to the smallest size needed to clean up the bores and use a 4.250 or 4.300 stroke crank with 6.7 or 6.8 long BB Chevy type forged steel rods, 10.5 to 11.0 compression ratio for pump gas with 1/16,1/16, 3/16 standard tension file to fit moly rings and a set of ported 440-1 heads with 1.6 ratio rockers and a Indy 400-3 intake and a 1050+ CFM Dominator carb and good fuel delivery system, solid roller cam with between 255 to 275 duration at .050 with as much lift that you can get up twocents scope
Re: Best engine combo for a 9 second Duster! [Re: Cab_Burge] #2938331
06/30/21 01:12 PM
06/30/21 01:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Build a New hemi..parts are fairly inexpensive... and think light about the total weight... the lighter you
make the whole car the quicker it is with less power you need,,, my car is very light at 2400# race weight
and I run in the 8s.... one other thing how quick do you want to run and how much money will you
spend.. making a car lighter is cheaper and and easier on parts
wave
Re: Best engine combo for a 9 second Duster! [Re: Gtxxjon] #2938346
06/30/21 01:35 PM
06/30/21 01:35 PM
AndyF Offline
AndyF  Offline
You need around 700 hp to run mid 9's at 3200 lbs. Any of the engines you listed can make 700 hp but you'll need really good heads for the SB and pretty good heads for a BB. If I had a customer who wanted to go rounds weekend after weekend in a 9 second Duster I'd probably LS swap it.
Re: Best engine combo for a 9 second Duster! [Re: AndyF] #2938358
06/30/21 02:13 PM
06/30/21 02:13 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Ouch...
Build a 512ci Big Block with INDY heads, and a GOOD convertor, Good suspension, and it shouldn't be that hard.
69 GTX 68 Road Runner
Re: Best engine combo for a 9 second Duster! [Re: AndyF] #2938372
06/30/21 02:49 PM
06/30/21 02:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
stirthepot
Re: Best engine combo for a 9 second Duster! [Re: justinp61] #2938376
06/30/21 02:54 PM
06/30/21 02:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
In anything under 3200 pounds take your pick.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best engine combo for a 9 second Duster! [Re: pittsburghracer] #2938381
06/30/21 03:00 PM
06/30/21 03:00 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What parts you have now?
Re: Best engine combo for a 9 second Duster! [Re: AndyF] #2938386
06/30/21 03:04 PM
06/30/21 03:04 PM
oregon
greendart408 Offline
oregon
This is the smart and cheap way after having my hands on a few in buddies rides. That being said, I'm a small block guy, all the same chassis, 727, 3200 lbs. all na....
Circa 06 ish w2 408 9.70s
Circa 08ish, same 408 with w5s 9.50s
Circa 12ish 430ci, Indy head. 9.30@144. Been on a hiatus doing a f2 deal with w8s since 15ish.
I know most wont agree but this is how I roll. I like to do more with less. I like the challenge
Re: Best engine combo for a 9 second Duster! [Re: MR_P_BODY] #2938388
06/30/21 03:06 PM
06/30/21 03:06 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
wave
This!
And in regards to the post about LS swaping the thing, Gen3 hemi is basicly an LS swap,only that the hemi is alitle better choice.
Re: Best engine combo for a 9 second Duster! [Re: Gtxxjon] #2938437
06/30/21 05:12 PM
06/30/21 05:12 PM
NC
440Jim Offline
440Jim  Offline
NC
Stroker 360.
Stroker 400.
Normal 440.
Stroker 440.
Big difference if you want to run 9.90 or 9.10
Also, depends on track elevation, 6,000 feet or sea level (less than 1,000 ft).
For a high 9 sec at 3100-3200 lbs (with driver) I would consider a Gen 3 hemi.
But with all my big block stuff, any 9 second would be a 511-540 CID stroker 440 wedge with Indy 440-1 heads. CNC ported.
Re: Best engine combo for a 9 second Duster! [Re: AndyF] #2938448
06/30/21 05:28 PM
06/30/21 05:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just when I THOUGHT I'd heard it all from you Mr Andy.......
Re: Best engine combo for a 9 second Duster! [Re: 440Jim] #2938450
06/30/21 05:30 PM
06/30/21 05:30 PM
PA.
"Little"John
"Little"John
PA.
Do a big block stroker and skip right over the 9’s and run 8’s. The parts to do it are surely available.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Best engine combo for a 9 second Duster! [Re: pittsburghracer] #2938496
06/30/21 08:21 PM
06/30/21 08:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do a 318, put a turbo on and run 8s. Heck awhile back I saw a 4 cylinder Volvo running 4.90 in the eighth.
Re: Best engine combo for a 9 second Duster! [Re: Gtxxjon] #2938570
06/30/21 11:30 PM
06/30/21 11:30 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Find a wrecked Hellcat, swap the engine and trans, tune as needed.
Re: Best engine combo for a 9 second Duster! [Re: Skeptic] #2938576
06/30/21 11:48 PM
06/30/21 11:48 PM
Boise
Moparteacher Offline
Boise
That's what I was thinking. Pick up a gen III and put a turbo on it.
Maybe change the rods, open the ring gap, programmable ECU, etc.
If you're starting with nothing may as well step into the 21st.
Re: Best engine combo for a 9 second Duster! [Re: Moparteacher] #2938589
07/01/21 02:00 AM
07/01/21 02:00 AM
NY
B1duster Offline
B1duster  Offline
NY
Mega block, 4.15 stroke 498, mildly ported Indy -1s, mild 650 roller, 1050 carb, Mid 9s,
add an nos plate and your in the 8s. Worked for me.
Page 1 of 3 1 2 3
