Dominator's got a Noonan Hemi TT wet block! #2937378
06/27/21 05:36 PM
06/27/21 05:36 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Dragula] #2937392
06/27/21 05:54 PM
06/27/21 05:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I hope he can make it work up I really like that B-body on the lift in the backround
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dominator's got a Noonan Hemi TT wet block! [Re: fourgearsavoy] #2937434
06/27/21 08:23 PM
06/27/21 08:23 PM
birdtracker Offline
birdtracker  Offline
I figure it will take him 3 or 4 races to get a handle on that . Very big step from the other motor. Birdtracker
Re: Dominator's got a Noonan Hemi TT wet block! [Re: birdtracker] #2937527
06/28/21 01:35 AM
06/28/21 01:35 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I couldn't place whose shop that was, but I knew the B body looked familiar. Joliet Joe Zolper's, seen it on FB. They had a post up a while back about Dominator's motor. Hope they can get it all figured out.
Re: Dominator's got a Noonan Hemi TT wet block! [Re: slantzilla] #2937539
06/28/21 06:06 AM
06/28/21 06:06 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
there all going that way,jj had a arm drop here a few weeks ago,zip tie had a hemi in it .it was the baddest car there and took out helfer in the final
Re: Dominator's got a Noonan Hemi TT wet block! [Re: dart games] #2937574
06/28/21 09:39 AM
06/28/21 09:39 AM
Dragula Offline OP
Dragula  Offline OP
I talked with Noonan the other day, and they are making water blocks and heads, and they had a number of builds in process. Based on my original post, Dominator already has his in the car and running & testing.
They are supposed to send me some info as their website is lacking anything with regards to the water blocks. Currently though, they are based around their 4.800" center line Hemi's....And you can have it done a couple of different ways. But they are a dry sleeve, and can be a dry deck as well, raised cam block only with 60mm cam bore and RCD gear drive. Max cubes appears to be 572ish due to clearance of the cam bore to the rods.
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Dragula] #2937665
06/28/21 01:40 PM
06/28/21 01:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Is that a new car too? I don't remember it sitting that low and never noticed the black paint on top. Maybe it's at least been painted?
Re: Dominator's got a Noonan Hemi TT wet block! [Re: justinp61] #2938020
06/29/21 02:02 PM
06/29/21 02:02 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes it is....
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Al_Alguire] #2938025
06/29/21 02:27 PM
06/29/21 02:27 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Yes it is....
Kinda surprised you would build a new car like that, since it has the same aero as a barn door.
69 GTX 68 Road Runner
Re: Dominator's got a Noonan Hemi TT wet block! [Re: JERICOGTX] #2938030
06/29/21 02:41 PM
06/29/21 02:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes it is....
Maybe he didnt BUILD a new car smile
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Al_Alguire] #2938032
06/29/21 02:47 PM
06/29/21 02:47 PM
Seaford, Va
Kindafast Online work
Kindafast  Online Work
Seaford, Va
I really hope he does good with his new " Mopar" Setup.
Glad he finally got away from brand X Now I wish everybody running a Mopar configuration Hemi would go to a Mopar body to.. Sure wouldn't see many fox bodies and some Chevys too.
6.50 @105.26
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Al_Alguire] #2938041
06/29/21 03:17 PM
06/29/21 03:17 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Yes it is....
Build, Buy, same thing when it comes to that. Still a barn door.
Re: Dominator's got a Noonan Hemi TT wet block! [Re: JERICOGTX] #2938044
06/29/21 03:21 PM
06/29/21 03:21 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Does it even matter that much in 1/8 mile?
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Al_Alguire] #2938070
06/29/21 04:16 PM
06/29/21 04:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes it is....
Cool! I hope he does well with it.
Re: Dominator's got a Noonan Hemi TT wet block! [Re: SRT6776] #2938121
06/29/21 05:55 PM
06/29/21 05:55 PM
I use to live near El Mirage dry lake in SO CA where they run some top speed time trials 4 to 6 times a year for SCTA, So CA Timing Assoc..
I had thought about building a car to race their until I found out that there is no money or any other rewards to race their even when you set a new record, in other words you pay, pay and pay some more to go fast. They gave you a one mile running start and timed you for 1/4 mile and you had a little over 2 miles to stop depending on the conditions of the lake bed at the time of the races.
One of the old timers ended up telling me that any one can make a car go 125.+ MPH, many can make the same car go 150 MPH but after that you need to double the HP or really reduce the wind drag to step up to go 175.+ MPH work
My message is it is not the distance, it is the speed that comes into play on wind resistance shruggy
My current S/P car runs 5.50 in the 1/8 mile at 125.+ MPH, it runs 8.86 ET at 150.+ MPH in the quarter mile. The last 1/8 mile takes 3.36 seconds and the car only gains 25 MPH whiney It shifts into high gear around the 400 ft. mark, best 60 Ft times so far are 1.24 boogie
I've wanted to go watch the racers at Bonneville Salt Flats for years but that may not happen now, some of those same racers from SO CA run their cars at El Mirage dry lake in the winter months.
That is the basis of most car racing in SO CA going back to the early1900S, I got to meet and become friends with one of those old time racers back in 1963 that raced at Murock (SP?) Dry Lake before WW2, which is now part of Edwards A.F.B.
I've learn that most drag racing carnage in the 1/4 mile is either at the starting line or in the last 300 FT before the finish line work
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Dragula] #2938808
07/01/21 04:58 PM
07/01/21 04:58 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Had my H20 Block couple of years now, hopefully get to the track this year, in my Street legal Cuda. Car build has taken longer than I would of liked grin
I also didn’t have the luxury of a fully built engine, another reason build took longer
521 Noonan H20, Twin 98’s, TH400, full tube chassis
Re: Dominator's got a Noonan Hemi TT wet block! [Re: mopar_mark] #2938826
07/01/21 06:51 PM
07/01/21 06:51 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
One of the nicest cars in the history of cars.
Re: Dominator's got a Noonan Hemi TT wet block! [Re: jim sciortino] #2938928
07/02/21 07:50 AM
07/02/21 07:50 AM
London, England
Gavin Offline
Gavin  Offline
London, England
It sure is....... grin
Re: Dominator's got a Noonan Hemi TT wet block! [Re: Gavin] #2938979
07/02/21 11:06 AM
07/02/21 11:06 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
"Street car."
Re: Dominator's got a Noonan Hemi TT wet block! [Re: jim sciortino] #2939023
07/02/21 01:45 PM
07/02/21 01:45 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
x2. That is absolutely gorgeous!!!!
