Denso alternator question
#2937449
06/27/21 08:50 PM
06/27/21 08:50 PM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I want to upgrade to the small Denso style alternator on my 1970 Dart, but my current setup uses a dual groove v-belt alternator pulley. Anyone know of a specific application where the alternator came with a dual groove pulley?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Denso alternator question
[Re: MadMatt]
#2937461
06/27/21 09:12 PM
06/27/21 09:12 PM
Posts: 6,282 nowhere
Sniper
nowhere
I want to upgrade to the small Denso style alternator on my 1970 Dart, but my current setup uses a dual groove v-belt alternator pulley. Anyone know of a specific application where the alternator came with a dual groove pulley? 88 and 89 Diplomats, trucks too I believe
[Re: mopowers]
#2937854
06/28/21 10:59 PM
06/28/21 10:59 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
You could always buy the alternator you need, then buy a pulley that'll work. Powermaster should sell 2-groove pulleys that'll work on denso alternators.
[Re: mopowers]
#2937861
06/28/21 11:52 PM
06/28/21 11:52 PM
Posts: 4,432 Michigan
MarkZ
Worthy
Worthy
Are you looking at the small block 60 amp Denso kit? I had one on a 360 and it came with a single groove pulley. You can actually run a belt from it directly to the crank pulley by going under the water pump. Some of the earlier water pumps had reinforcement ribs and would need one of those ribs notched.
