Stand alone engine control for VVT engines???
#2936695
06/25/21 01:10 PM
06/25/21 01:10 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
What is the easiest way to stick a junk yard 5.7 or 6.4 VVT engine into an old muscle car? I have one of each and a customer who wants me to stick one in his 72 road runner. Is there a controller and harness that runs a complete drop out engine? If nothing like that is available yet would an MSD hemi 6 control the coils on a VVT engine with a carb or do I need to swap tone rings and lock cam...?
Re: Stand alone engine control for VVT engines???
[Re: fbs63]
#2936725
06/25/21 03:36 PM
06/25/21 03:36 PM
Posts: 4,427 Michigan
MarkZ
Worthy
Worthy
Holley Terminator X can control the EFI and VVT. They've got an entire swap kit with harness.
[Re: MarkZ]
#2936885
06/26/21 09:49 AM
06/26/21 09:49 AM
Posts: 1,397 Toronto Ontario, Can
Glen440
If you want easiest, get the mopar kit. If the engines are stock they will run like the factory cars as they have stock tunes. Everything else you need to tune yourself or get someone to do it.
87 dakota 6.1 hemi
[Re: Glen440]
#2937503
06/27/21 11:04 PM
06/27/21 11:04 PM
Posts: 2,255 IL
furious70
IL
well, easiest is mopar kit if you have a car engine. Cheapest is MS3 Holley is a good choice
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: 1Fast340]
#2944412
07/17/21 10:10 PM
07/17/21 10:10 PM
Posts: 1,967 ID/MT
Cheeto
ID/MT
"Use the Mopar kit"....does anybody have info on a kit for a 6.1? All I can find is old Google results for 5.7 and 6.4. I've been waiting over 2 weeks for a response from Holley regarding their stuff and I'd gladly go with Ma Mopar if that is an option. 2008 Charger SRT8 6.1 into 1970 Barracuda (currently 440)
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: HotRodDave]
#2944487
07/18/21 09:23 AM
07/18/21 09:23 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
What is the easiest way to stick a junk yard 5.7 or 6.4 VVT engine into an old muscle car? I have one of each and a customer who wants me to stick one in his 72 road runner. Is there a controller and harness that runs a complete drop out engine? If nothing like that is available yet would an MSD hemi 6 control the coils on a VVT engine with a carb or do I need to swap tone rings and lock cam...? Easiest is Holley terminator X Cheapest is changing the reluctor wheel to an ealier version and run a carb with MSD Hemi 6. ( Don't know why Holley hasn't offered thisfor the 64 tooth as the have it for the LS). Pick your poison. Even cheaper way would be to mount a 32 tooth wheel to the Balancer? Matt
[Re: MattW]
#2944543
07/18/21 12:29 PM
07/18/21 12:29 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
What is the easiest way to stick a junk yard 5.7 or 6.4 VVT engine into an old muscle car? I have one of each and a customer who wants me to stick one in his 72 road runner. Is there a controller and harness that runs a complete drop out engine? If nothing like that is available yet would an MSD hemi 6 control the coils on a VVT engine with a carb or do I need to swap tone rings and lock cam...? Easiest is Holley terminator X Cheapest is changing the reluctor wheel to an ealier version and run a carb with MSD Hemi 6. ( Don't know why Holley hasn't offered thisfor the 64 tooth as the have it for the LS). Pick your poison. Even cheaper way would be to mount a 32 tooth wheel to the Balancer? Matt 64 tooth ?
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2944548
07/18/21 12:45 PM
07/18/21 12:45 PM
ric3xrt
Trumbauersville PA
Stanke VVT plug, it keeps the VVT gear locked with oil Pressure, and doesn't allow it to blead out and let the gear retarded it's self.......which it will with the OEM Solenoid if it's not getting signal.
[Re: RTSrunner]
#2945052
07/20/21 07:36 AM
07/20/21 07:36 AM
Glen440
"The system is SRV calibrated for 4,800 RPM, also not adjustable." ....from the Edelbrock description of the unit. Does this mean it is rev-limited to 4,800 RPM? I tried to search the meaning of "SRV" as related to auto computers but to no avail. The SRV is the short runner valve, the active intake manifold. It switches from long to short runners at 4800 rpm. There is no benefit to changing that rpm from a dyno test on engine masters. The Holley terminator x efi you can use whatever rpm you want.
87 dakota 6.1 hemi
[Re: ric3xrt]
#2945150
07/20/21 12:16 PM
07/20/21 12:16 PM
MattW
Ontario Canada
What is the easiest way to stick a junk yard 5.7 or 6.4 VVT engine into an old muscle car? I have one of each and a customer who wants me to stick one in his 72 road runner. Is there a controller and harness that runs a complete drop out engine? If nothing like that is available yet would an MSD hemi 6 control the coils on a VVT engine with a carb or do I need to swap tone rings and lock cam...? Easiest is Holley terminator X Cheapest is changing the reluctor wheel to an ealier version and run a carb with MSD Hemi 6. ( Don't know why Holley hasn't offered thisfor the 64 tooth as the have it for the LS). Pick your poison. Even cheaper way would be to mount a 32 tooth wheel to the Balancer? Matt 64 tooth ? Reluctor wheel late model is 64 ?
