Re: Billet Specialties wheel hitting caliper??
[Re: wkroncke17]
#2935141
06/20/21 10:00 PM
06/20/21 10:00 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
[censored] . I had the same issue . I have same wheel . i swapped from drum to discs using a kit with GM metric (caddy) caliper . Darn was i annoyed . As the caliper is cast iron i shaved it a little to get clearance , used a mini belt sander . The rim has a deep drop centre , with the bigger back space bupbow
Maybe Dr Diffs mustang based rears would fit better ? But from my distance you just make it work
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2935154
06/20/21 10:57 PM
06/20/21 10:57 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Tex I have what sounds like the exact same kit. Caliper is ‘83 Eldorado? Rotor is late 80’s Lincoln. I have a good machinist, should I have him remove some material? I’ve owned this damn thing since 1983 and now I’m trying to do things right with good parts, I keep having setbacks.
[Re: wkroncke17]
#2935156
06/20/21 11:21 PM
06/20/21 11:21 PM
tex013
Sydney,Australia
Tex I have what sounds like the exact same kit. Caliper is ‘83 Eldorado? Rotor is late 80’s Lincoln. I have a good machinist, should I have him remove some material? I’ve owned this damn thing since 1983 and now I’m trying to do things right with good parts, I keep having setbacks. yes sounds similiar , mine has a dual pattern rotor , Pontiac ? I bought mine as new but old and unfitted . Not sure a machinist will be excited trying to remove a curved area . Ask him , or even use a 4" grinder with a coarse flapper wheel . Mark area to linish,shave . it wasnt a lot . You could even do it on car i did . this also saves crap getting into caliper areas it shouldnt Tex
[Re: tex013]
#2935236
06/21/21 10:12 AM
06/21/21 10:12 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Just trim the caliper to fit. Plenty of meat there to take out what you need.
[Re: Al_Alguire]
#2935416
06/21/21 08:42 PM
06/21/21 08:42 PM
wkroncke17
Wisconsin
Just trim the caliper to fit. Plenty of meat there to take out what you need. Took your word for it and started grinding. About an hour later, the wheel fits! How’s it look?
[Re: Moparteacher]
#2935524
06/22/21 07:00 AM
06/22/21 07:00 AM
wkroncke17
Wisconsin
A little bit of black high heat paint and nobody will know the diff.
Don't forget to lube the caliper pins at the o-rings with some synthetic grease. I will do that, thank you! I thought I should take them off, clean them and hit them with the paint. At least the car will be a bit lighter after all of that grinding?..😂😂
[Re: Moparteacher]
#2935733
06/22/21 05:36 PM
06/22/21 05:36 PM
tex013
Sydney,Australia
Don't forget to lube the caliper pins at the o-rings with some synthetic grease. i used silver Tex
