Wrinkle Paint for Air Cleaner
#2933094
06/14/21 09:34 AM
06/14/21 09:34 AM
Posts: 309 Dearborn, Michigan
gtxncuda
Dearborn, Michigan
Gents, I'm attempting to repaint my OE air cleaner on my 71 Cuda. The original wrinkle paint has been flaking off along edges of the lid and showing a spec of rust here and there. So I cleaned everything in the solvent washer, the bead blasted the lid and housing completely to bare metal. Cleaned everything and wiped down with lacquer thinner, then primed with VHT brand rattle can primer. Allowing a day to dry, then scuffed lightly with ScotchBrite, wiped clean again, then painted with VHT brand black wrinkle paint applying multiple coats (EXACTLY per the directions) allowing dry time between coats. I even baked it in the oven (per instructions) and the results have been less than satisfying. It's wrinkled fine in some areas, but not others. Looks like I need to start over. Can anyone recommend another brand of rattle can wrinkle paint that they've used successfully? I do not have the equipment (or talent) to do this with a proper spray gun. Suggestions are much appreciated! As always, thanks all!
1971 Cuda 340 auto 2013 Mustang Boss 302 L/S 1969 Road Runner RM21 440 4 speed
Re: Wrinkle Paint for Air Cleaner
[Re: Stanton]
#2933104
06/14/21 10:05 AM
06/14/21 10:05 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I don’t remember using a primer - Bare metal
I also painted in the direct sun - Sunny day , a few coats
I never have used the oven method
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: topside]
#2933135
06/14/21 11:31 AM
06/14/21 11:31 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Powdercoat is the only way to go. The spray can stuff is a crap shoot.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: gtxncuda]
#2933466
06/15/21 08:58 AM
06/15/21 08:58 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
I had the one for my Demon done by a good local powdercoater. Might be a little too shiny for a correct resto, but I think it turned out great. Disregard the old yellow plug wires...they're temporary.
[Re: larry4406]
#2933799
06/16/21 01:44 AM
06/16/21 01:44 AM
Posts: 1,757 Phila
PhillyRag
Phila
Mike Ross of BEA has nailed this via powder coating. Powder wrinkle is nice, but few I did weren't as "wrinkled" as an oem or can appearance. BUT, it definitely was more uniform. Spray wrinkle paint relies upon "trapping" excess solvent between layers to crete that effect. That's why you apply Heavy Coats & a few minutes between coats. Trapping more solvent while less time to disperse between coats. Basically less-flash & heavy-coats to produce. Too high room temp, or in sunlight, may allow more solvent to disperse between coats. Too heavy-a-coat(s) & get runs afterwards. Sure is a juggling-act for sure. Just my understanding.
[Re: PhillyRag]
#2934039
06/16/21 08:07 PM
06/16/21 08:07 PM
Posts: 571 Denver,NC
hemiheadNC
Denver,NC
...Harley case/cylinder spray is the BEST...not cheap but I did my hemi valve covers 5 years ago and they still look like new...
I'm lost in the 60's and DAMN proud of it.
