Re: aluminum media blast ?
[Re: Neil]
#2932979
06/13/21 10:09 PM
06/13/21 10:09 PM
Posts: 1,755 Phila
PhillyRag
Phila
Glass bead I think is what is used on aluminum. It cleans the pores and makes the surface uniform, but it also leaves the surface far from shiny. Glass beads is a "mild" form of shot-peeening on softer surfaces. Larger beads if surface ruff or very pouris.
[Re: 71birdJ68]
#2933086
06/14/21 09:17 AM
06/14/21 09:17 AM
Posts: 18,157 Mass
DAYCLONA
Mass
The only safe way to blast them is vapor blasting, or sometimes called water blasting. It will leave them mostly like new. Another type of blasting, especially glass will mess them up. Elbow grease is the only thing that will polish them and lots of it. "vapor blasting" is nothing more than glass bead and water solution, soda blasting on "clean" aluminum is about the only way to go as not to add any texture to the surface prior to polishing....
Re: Challenger Glove Compartment Locking mech
[Re: 70VERT]
#2933102
06/14/21 09:55 AM
06/14/21 09:55 AM
Posts: 8,874 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I've purchased a new locking key cylinder for my 70 Challenger glovebox from classic industries. I cannot figure out how the keyed cylinder goes into and out of the latching mech. Can anyone tell me the trick for installation/removal? I managed to get it into the latching cylinder and now I am stuck. Thanks This thread is about blasting valve covers. Go start you own thread !!
