70 Cuda tire options #2932434
06/12/21 09:48 AM
06/12/21 09:48 AM
Abilene, Texas
fastmark Online content OP
fastmark  Online Content OP
Abilene, Texas
What would be the std wheel and tire option on a 70 440 4 barrel Cuda with auto trans and option 3.55 suregrip package. The previous owner bought the car in 76 and I had a bunch of 14” rally’s that came with it but it always had ET mags since he bought the car. No buildsheet since it’s an LA built car. Nothing on the tag to help either.
Re: 70 Cuda tire options [Re: fastmark] #2932442
06/12/21 10:25 AM
06/12/21 10:25 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the STANDARD tire was a GOODYEAR POLYGLAS F70-14 w/Raised White Letters on a 14x6.0" steel wheel painted body color with the stainless steel "PLYMOUTH DIVISION" hub cap
Re: 70 Cuda tire options [Re: 6bblgt] #2932443
06/12/21 10:37 AM
06/12/21 10:37 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Without the build sheet is there really any way to tell for sure what tire and wheel combination any particular car came with , outside of the standard tire / wheel option????
Re: 70 Cuda tire options [Re: fastmark] #2932635
06/12/21 09:29 PM
06/12/21 09:29 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
It has always surprised me to the number of high performance models of the muscle car era that came with 14's...not just Mopar. My 1970 440 Cuda with the 3:55 came with the optional 15 inch rims and Goodyear Polyglas RWL In terms of aesthetics, the 15's fill the wheel wells so much better.
David
Re: 70 Cuda tire options [Re: David1971] #2932685
06/13/21 01:14 AM
06/13/21 01:14 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the OPTIONAL E60-15s are roughly ~3/8" shorter in diameter & ~7/8" wider than the STANDARD F70-14s (at least the reproductions - original tires may differ slightly)
interesting window sticker work did the original owner get a mandatory "space saver spare tire" for FREE? scope
Re: 70 Cuda tire options [Re: gtx6970] #2932689
06/13/21 01:28 AM
06/13/21 01:28 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there are a number of original details that can point to possible original tire/wheel combinations (cars were built by people and any of the following could've happened by mistake)
1970 'cuda:
red painted brake drums indicate "ROAD" or "RALLYE" wheels
tire pressure decal "62" F70-14s VS. "59" E60-15s, etc.
speedometer pinion 36 - F70-14s VS. "37" E60-15s (with 3.55s)
lower control arm bumper spacers with 15" tires
space saver spare was a "mandatory OPTION" with 15" tires & OPTIONAL with 14" tires (& stud to mount spare in trunk was in different position full size VS. space saver)
Re: 70 Cuda tire options [Re: 6bblgt] #2932690
06/13/21 01:33 AM
06/13/21 01:33 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
STANDARD T87 - F70-14 w/RWL GOODYEAR POLYGLAS tires mounted on OPTIONAL 14x5.5" W21 - "RALLYE" wheels was the most common configuration of a non-HEMI/non-AAR 1970 'cuda
moparts 1970 cuda tires.jpgmoparts 1970 cuda hub caps-wheel covers-wheels.jpg
Re: 70 Cuda tire options [Re: 6bblgt] #2932699
06/13/21 05:12 AM
06/13/21 05:12 AM
Abilene, Texas
Abilene, Texas
Thanks Dan. I’ll look at these things the tire sticker may still be there.. I did not look.
Re: 70 Cuda tire options [Re: fastmark] #2932720
06/13/21 08:39 AM
06/13/21 08:39 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Mark,
If you do decide you want 14” plain wheels, I still have that date code matched set of 5 I got from you several years ago.
Tom
68 Charger
70 Cuda
Re: 70 Cuda tire options [Re: 6bblgt] #2932734
06/13/21 09:44 AM
06/13/21 09:44 AM
BDW Online content
BDW  Online Content
1970 'cuda:
Any pics for the different hold down location? Different floor pan or just a different / hole that could be used?
Re: 70 Cuda tire options [Re: BDW] #2932752
06/13/21 11:01 AM
06/13/21 11:01 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Dan.
Applying same question to a 1970 challenger 340 as example.
Wasn't the E60.15 tires standard equipment?
Using my 1966 Satellite as another.
Wasnt the 7.75.14 blue streak the only avail tire....or were there options for it as well. I know there were no 15" tire options in 1966 correct?
Re: 70 Cuda tire options [Re: BDW] #2932753
06/13/21 11:03 AM
06/13/21 11:03 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1970 'cuda:
Different bolt length in a different mounting location on same bracket
Re: 70 Cuda tire options [Re: FC7cuda] #2932789
06/13/21 12:18 PM
06/13/21 12:18 PM
Abilene, Texas
Abilene, Texas
Originally Posted by FC7cuda
Mark,
Tom
Thanks. I’ll keep that in mind.
Re: 70 Cuda tire options [Re: BDW] #2932843
06/13/21 03:52 PM
06/13/21 03:52 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
same bracket - different stud in a different location "space saver" VS. full size spare in a E-body scope (convertible used a different bracket welded to the trunk floor)
Re: 70 Cuda tire options [Re: gtx6970] #2932853
06/13/21 04:12 PM
06/13/21 04:12 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Dan.
the original offering (mid-September '69) of a 340 package for the Challenger was expensive at ~$250 & included the E60-15s, but had W21 wheels & W34 spare as additional "mandatory OPTIONs" (another ~$56) realcrazy
the OPTION package was re-vamped around late-October & the 15" tires/wheels were no longer included, but they were on the OPTION list
Correct, there wasn't a big OPTION list on '66 model year cars - HEMI OPTION included 7.75-14 "blue streaks" on 14x5.5" wheels
Satellite included bucket seats, console, full wheel covers w/spinner and other equipment exclusively (only '66 Plymouth b-body with these items)
Re: 70 Cuda tire options [Re: 6bblgt] #2932867
06/13/21 04:56 PM
06/13/21 04:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Thanks Dan,
When i had my former challenger 340 I had read somewhere the 15s were part of the pkg. wasnt aware that changed mid year
And I was pretty sure the 14" and blue streaks and spinners were the only wheel /tire / hubcaps choice on a Satellite
Where as Belvedere had a couple different hubcaps options
Still trying to decided if I want to put the stock wheels and hubcaps on the car ,,,,as a part time wheel option ,
But IF I do Im 99% sure they will be whitewalls
And using a 68-70 B body for example , they had the crayon markings on the bottom of the decklid . Was this the same on other car lines ?
Sorry to the OP for dragging the topic off topic
Re: 70 Cuda tire options [Re: gtx6970] #2932870
06/13/21 05:01 PM
06/13/21 05:01 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
AFAIK b-body ONLY at LYNCH RD. Detroit, MI assembly plant
Re: 70 Cuda tire options [Re: 6bblgt] #2933446
06/15/21 08:20 AM
06/15/21 08:20 AM
WV
Little Detroit Offline
WV
those were not the only details of the 14 inch tire , they also had a different Jack hook. same number , but the jack hook had no hole in the side to slide over the the spare tire stud. the jack hook was mounted under the full size spare tier pinched betweened the tire and the trunk floor. see pic.
1970 full size jack hook #2.JPG1970 full s jack hook #3.JPG1970 nos collapsible spare jack hook #2.JPG1970 nos cuda collasapible spare jack hook #2.JPG
Re: 70 Cuda tire options [Re: Little Detroit] #2933495
06/15/21 10:42 AM
06/15/21 10:42 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Some great information in this thread guys! Dan as always you are a wealth of information.
Matt
Re: 70 Cuda tire options [Re: 6bblgt] #2933625
06/15/21 04:46 PM
06/15/21 04:46 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
When I purchased the Cuda about 2 years ago, there was no spare in the trunk. I do not not have the build sheet in order to verify the "space saver"....which is what it should have came with from Hamtramck. The short style stud is in the trunk at the space saver location.
