65 - 66 C body fuel tank questions #2932405
06/12/21 02:22 AM
06/12/21 02:22 AM
Missouri
StrokerPost Offline OP
Missouri
Is there a difference between a 65 and 66 Fury fuel tank, seems like there was something different but cannot remember. Does anyone know if tanks for a 66 are available in the aftermarket? Thanks for any info.
Re: 65 - 66 C body fuel tank questions [Re: StrokerPost] #2932412
06/12/21 07:31 AM
06/12/21 07:31 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
65 is a 1 year, Plymouth only side fill. The rest were rear fill.
Van's has the 66 tank if they aren't out of stock.
Kevin
Re: 65 - 66 C body fuel tank questions [Re: Twostick] #2932529
06/12/21 03:27 PM
06/12/21 03:27 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Kevin
They also have the 65 tanks now if not out of stock. I have one in my car.
Re: 65 - 66 C body fuel tank questions [Re: Twostick] #2932609
06/12/21 07:59 PM
06/12/21 07:59 PM
Missouri
Missouri
Kevin
Sorry, been away for quite a while...Van's???
Re: 65 - 66 C body fuel tank questions [Re: StrokerPost] #2932669
06/12/21 11:29 PM
06/12/21 11:29 PM
Missouri
Missouri
Kevin
Ok, I found them but of course no 66 tanks. Everything else, straps, bolts, pads and grommet but no tanks. This is always the case when I've tried to find a 66 tank. confused Any other suggestions?
Re: 65 - 66 C body fuel tank questions [Re: StrokerPost] #2932672
06/13/21 12:00 AM
06/13/21 12:00 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
Spectra has a listing for a 67 tank. I get conflicting reports on whether it fits a 66 or not. Some people report it fits just fine, others say the rear axle will hit it. I don't even know how that could be possible if the original tank cleared it.
With the exception of the 65 Fury with the side fill tank and the orphan 65 only drivers side motor mount on all of them, C-bodies were pretty much identical underneath from 65 to 68, the slab side years.
https://ecat.spectrapremium.com/products/CR20B
Kevin
Re: 65 - 66 C body fuel tank questions [Re: StrokerPost] #2932674
06/13/21 12:02 AM
06/13/21 12:02 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
If you have some measurements, check out the b body tanks - something will fit
