MSD 6A rev limiter possible? #293233
04/19/09 08:03 PM
04/19/09 08:03 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I've decided after having my 6A box for several years that I need a rev limiter. Is there a practical way to do this with the 6A box? I would rather not buy and wire in another box, but if that is the best or only way, then I'ld do it. Thanks!
Master, again and still
Re: MSD 6A rev limiter possible? [Re: DaveRS23] #293234
04/19/09 08:07 PM
04/19/09 08:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Is there a plug-in on the side? There's a separate rev-limiter box from MSD that just plugs in, as I did on my 6T.
Re: MSD 6A rev limiter possible? [Re: topside] #293235
04/19/09 08:11 PM
04/19/09 08:11 PM
New York
DartS Offline
DartS  Offline
New York
I sent my 6A MSD box in and they converted it to a 6T. I had this done in the late 90's and it was $30.
Re: MSD 6A rev limiter possible? [Re: DartS] #293236
04/19/09 08:49 PM
04/19/09 08:49 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
you have to have a 6T/6TN/6HVC for the 8738 rev limiter to work. I actually have the stock ignition and the 8728 rev limiter, but that won't work with the 6A either.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
